VYRUS
I’ve been accused of being a lot of things, but never AI. No, It’s just me at my grandson’s little league game, killing time.
Would you like to regenerate the title as well as the summary?
George would you be able to provide me the contact info you used to get your claim taken care of? I have this same issue with my 2014 Sprinter. The dealer that performed the service refused to cover the work telling me the sensor that was bad isn't covered. It cost me over $3000. I would really appreciate this information and possibly the wording you used? Thank you. Michelle. mchgall@comcast.netSprinters are very reliable prior to 2007/8 and reasonably reliable after about 2016. The major issue is terribly engineered, EPA regulated injection of Diesel Exhaust Fluid (DEF). Malfunction of any of the DEF system components such as DEF heater, pump, NOx sensors will give owners 10 engine startups for the issue to be addressed by the dealer.
It happened to my 2013 van twice on the return route from Key West Florida to Oregon in Texas. Total cost was almost $5K which I was able to recover it (dealer didn’t honor my warranty) by communicating first directly with Daimler Benz in Germany than US. One year later I received a decent bonus with additional 4 years warranty. Since than my Sprinter works great.
Best source for information is on the Sprinter Forum. Sprinter-Source.com
You got most of the high points correct, but because BlueTec diesels are so complicated, here’s a few details that expand on your explanation.We own a 2018 3500 Road Trek with the 3.0 Deisel and would say that I have done a lot of research on oil brands and maintenance needed to head off potential problems. If you are going to do a lot of stop and start city driving this would be a problem. If you are primarily using on highway and understand how the DPF system works you will be fine. As far as fuel mileage we get around 16mpg on avg with our unit weighing around 9,000 pounds and driving the speed limit. Oil makes a difference if using BIO and so does your driving habits. on the highway I have stopped worrying about Bio use. I installed a catch tank on the Oil separator hose (EGR Valve) to capture soot filled oil headed to the air intake. I use Motul motor oil at the time being because I started using Oil Geek for analysis and made a change to reduce wear and look for maximum change interval. Keep you DEF tank topped off as much as possible to avoid the crust build up in the tank. Crust may be the wrong word, but when you spill it and see the residue after it dries you will understand what I am talking about make sure tank lid is tight. I run additives in the fuel to help with lubricity and Cetane. Cetane helps with horsepower and you don't want the fuel pump to become a problem. While driving we use a monitoring device to watch exhaust gas temps, DPF percentage, average DPF regens, oil temp and CPU voltage. The device we use is called Blue Driver. Note: Some ware along the line our unit has had a software update, and we are at 150 miles average regen and it will regen while idling and if you shut off the engine during regeneration it will restart regen when restarted. I believe this programing is how Mercedes delt with the no start problem even though for me and mostly highway driving think the 400-mile interval of old would be better. Regeneration uses fuel to heat up the DPF and raises exhaust gas temps to around 1300 degrees. Mercedes fuel injection system to the DPF is not direct to the DPF like most but instead to the cylinders that can cause increased fuel dilution to the oil so keeping an eye on your oil level is important and oil analysis will tell you if there is fuel present. To summarize we love the Mercedes for the look, ride and by taking care and understanding the unit hope to get a lot of traveling
I was exchanging messages with customer representative, took a while to reach a correct person. At some point I contacted Daimler Benz in Germany and was transferred to US. Customer Support | Mercedes-BenzGeorge would you be able to provide me the contact info you used to get your claim taken care of? I have this same issue with my 2014 Sprinter. The dealer that performed the service refused to cover the work telling me the sensor that was bad isn't covered. It cost me over $3000. I would really appreciate this information and possibly the wording you used? Thank you. Michelle. mchgall@comcast.net
