It may or may not be exactly the same as our 07 Chevy because you are on the previous GM chassis platform and we aren't, but the models are very similar.
On ours, there are screws up from the underside of the awning that you need to remove and then you can pull out the bottom and twist it up to get the top to release.
If you need to get rid of it entirely, you will be in for some work as the three brackets are pop riveted to the fiberglass roof with spacer under them to get it to match the curve of the roof. IIRC the spacers are separately pop riveted under neath the awning to hold it together with the awning removed. There appears to be a double plate inside the van to reinforce it from pulling out easily. If you take out the rivets and have the inside plate move, you may not be able to reinstall in without taking it apart on the inside which would be a lot of work.
