I have 70k mile and have had right rear bearing fail three times. Dana 60 semi floating with wheel spacers
Thoughts?
Semi floating axle running at near max load and with extra bearing stress of wheel spacers pretty much raises the risk factor compared to stock a lot.
You don't say what model/year you have or what your wheel weights are so that is unknown.
Also important is what wheels are on it as for the Chevies it is very easy to get the wrong offset and that would make the wheel spacer issue even worse for bearing load.
Any time you get a wheel bearing failure on a semifloater that uses the axle as the inner race, you should really replace the axle along with the bearing, and take a good look at the fit of the outer race in the axle tube. A hot bearing will reduce the strength of the axle right at the point of max loading, so don't risk it. A broken axle on a semi floater can let the wheel hub and wheel to come completely off the van, dropping the van on the pavement. Full floaters can break axles and all that happens is that you coast with no power, but the wheel stays in place.
It is also a remote possibility it could have wrong axle in it as they are different side to side, IIRC.
Take a quick look to see if the camber on the side that fails looks correct compared to the other side and purely vertical. That will help tell you if an axle tube has come loose from the extra load from the spacers and maybe wheels.
We don't hear of a huge lot of wheel bearing failures, but they certainly happen, as do broken axles. 3 in a row on one wheel would indicate something else is going on with it or the repairs have been poorly done, IMO.
