battery tray slides
roadbiker1
Feb 3, 2020
59
Oregon
On a 2008 210 Pop, battery slide out tray has worked for years until recently when would not fully extend,
so a Sawzall solution revealed much rust in the ball bearings in the sliders. I had shot spray white lithium grease
in them last year for good practice, did not save me. I will now pay more attention to all the sliders, promise,
am now looking for replacement sliders.. if you have a model # for the OEM sliders, please send. Thanks!
There is:was a discussion on here a while back. I used automotive grease on all my slides after reading that post!
I wash my battery slides with water every 6-8 months. Then spray Boeshield on to protect.
Having worked on and around ball bearings as part of my duties I would never spray any open bearing with water, never.
Here's my thinking. The battery acid gets into the bearing lube and causes corrosion. That's what happened to me on my original slides, even though I lubed them every year. So with the new slides I lubed them initially. Then at 1 year I cleaned the slides with water when I sprayed the battery box out. Then I blew the water out as best I could with an air gun. I set a fan to blow on the slide box for a couple hours to dry things out. Then reapplied the lubricant. Sound like a lot of work but doing it as part of cleaning off the batteries and the battery box it really wasn't that much extra effort.
You should not have acid leaking out of your battery, if its over filled or overcharging you have issues that need to fixed. My battery box is dry with No signs of moisture or damage.
This is not a bad way to handle it at all IMO, as long as the spray lube is one that clings and seals out the water and acid. I have seen slides in RVs a lot, but even more in factories that are really harsh environments.
I usually pick one of two main ways to handle slides, and both work most of the time.
Cleaning, lubing and then repeating works fine unless there is a very heavy loading of sand or abrasive that get into tracks. The rear one behind the rear wheel was like that. The killer is that folks try to cure it by using a short of spray grease into the slide and all that does is catch the sand and run it through bearing balls.
If I run into those situations or where there are corrosive vapors all the time, I will use heavy grease like chassis or wheel bearing grease and pack the track full to prevent air, water, sand, corrosive vapor from getting into it. Yep, it is messy, but you might appreciate when it is clean up time because now all the dirt is on the surface and many times you can just wipe off the grease and dirt layer and repack it full. Much messier if the dirt and water get past the grease though.
Stainless tracks and a pressure washer work great together as you use the dry lube and not worry about corrosion, only dirt, which shouldn't stick to dry lube.
I'm not sure if our 2010 battery tray is similar, here's what I did, may be of some use...
We still use the wet cell batteries, and I keep the compartment clean. Whenever these batteries fail I'll replace them with AGM, but for now they're ok. A key help was that after the repair I replaced the leaky old battery cell caps. Yes, there's vapor but no more seepage down the sides. All is still OK today.
I have a 06C210P and replaced mine with these last year.
Amazon.com
SHUHANG 1 Pair 150 lb Load Capacity Heavy Duty Drawer Slides 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 Inch Full Extension Ball Bearing Rails Side Mount Cabinet Glides RV Tool Box Runners​
Hope that helps.
