So here is a bit of a mystery for the smart minds on this forum...
A few days ago I was sitting waiting in our camper in a parking lot while my wife ran an errand. It was a bit hot and I only expected to be there for an hour or two so I turned on the AC running off my two 100A Battleborn LiFEPO4 batteries through my Xantrex XC2000. It started up fine and ran for a minute or two and then stopped. This surprised me as my Victron 712 monitor showed fully charged and all the other electrical 12v items were still working. I tried to start the AC again and it wouldn't start.
I'll cut the story down and get to the conclusion. When put under heavy load (~110-130A) the voltage on the batteries was dropping below 11.5v and the inverter was cutting off. I have never seen this type of voltage drop on the Battleborns. Normally they drop at most to something around 12.9V under a very large load, but not below 12v.
I ran the generator to see if perhaps my BMS was miscalibrated. The charge rate maxed out at about 30A and they did take a charge for a bit beyond the 100% point, but not that much beyond it.
The next day I went to lower the loft bed that is powered by twin 12v motors and the lights began to flicker. This type the load is only about 20A and the voltage was dropping down to 10.7V during bed movement. This was after having been plugged into shore power for most of the day.
Thinking this might be a loose connection issue I went under the camper and removed and then reattached several of the connection points from the battery. I also tried running off of just the converter (disconnecting the house battery) and everything works fine. If I do the same from the alternator everything works fine as well. The problem appears to be isolated to the two batteries.
The following day the batteries stopped working entirely. They show no voltage when disconnected and when provided with a voltage the BMS does not 'wake up' and begin accepting a charge. Just minutes before they died I had gone under the van and measured the voltage on them when they were physically disconnected from camper. The multimeter read 13.6v (which should be full charge).
I am waiting to here back from Battleborn about what the issue might be. In my internet searches I have found several other people on different forums describing this exact same problem with their fairly new and lightly used Battleborns. Discouragingly, none of them posted a resolution to their problem so I am still in the dark as to the cause or solution.
So my questions for this group are the following:
1. How could two batteries operating in parallel fail simultaneously? For those not familiar with Battleborn they have an internal BMS that protects against most failure modes.
2. Is this a BMS issue or a lithium cell issue? The battleborns are made up of four modules, each with a whole bunch of basically D-Cell sized cylindrical cells in parallel, and then the four modules are connected in series. For the battery to completely fail you would need failure of all of the cells in a single module, and this would have to happen on both of the batteries. This seems extremely suspicious.
3. What could have caused this failure? As far as I know I have never operated the batteries outside of the Battleborn specs, except for a small handfull of time when I charged them at about 0.55C during testing of my system (the spec limit is 0.5C). 130A load is well within the 200A continuous rating for the parallel batteries. The inverter can't even make use of the over 400A surge capacity of the batteries even on AC startup.
4. Is there a way this could still be a loose connection issue (e.g. connection passes voltage but cannot support high-current draw)? If so, why does everything work when the van is running? I tested the connections I can access (all but the ones attaching to the battery posts and the parallel wire connections between batteries).
Other thoughts on the situation are also appreciated.
