Best Replacement Options for 2008 Roadtrek 210 Battery Compartment Slides
Original Member Title: 2008 Roadtrek 210 Battery Compartment Slider Fix/replacement
A member with a 2008 Roadtrek 210 bent a welded battery tray slide while pulling the house battery drawer out farther than usual, likely after breaking the plastic stop. They were concerned that the original 12-inch slides did not provide enough overlap or support for roughly 150 pounds of batteries and planned to add a wood support when extending the tray fully.
Several members reported similar Roadtrek battery slide issues. One used wood wedges after the slides failed, another had...
youngnretired
Jun 8, 2025
318
Green Bay
As I was removing the house batteries last fall to bring the batteries home and put into the garage, I needed to pull the battery compartment tray out further than we needed anytime before when we'd check water level in the batteries. The left side dropped and I find that I bent one of the slide rails. Closer inspection has the plastic piece at the end of the slider attached to the chassis was also broken, which I probably pulled the drawer out too far and broke the plastic as I believe it's purpose is a stop. Unfortunately, these slides are welded on to both the chassis and drawer. I have a welder, but this is going to be a little too detailed for my knowledge level to fix.
For the future, I'm going to cut a piece of wood to support the drawer so that when I have to pull the drawer out far next time it has support at it's furthest point and not completely dependent on the side rails. It also seems that the amount of "overlap" between the coach and drawer slides with the intermediate piece isn't sufficient to support 150 pounds being supported by about 1-2" of slide rail.
Does anyone have any recommended slide rails to use that will provide better support for this, or thoughts or other ideas?
The crappy battery slideouts on my 2007 190P totally gave out. I jammed wood wedges around each battery, which so far have kept them secure. They are easy to remove if needed to access the batteries. Since switching to AGM, I haven't had to do this.
We had the same problem. Our repair guy was,able to put new slides from Accuride. They fit and work great. It was a bit tedious job. The Accuride company customer service is very helpful.
This may have some info if you go any further with that tray.
Something that helped the loading on the slides was placing a .25" nylon spacer under the tray. Takes a portion of the battery weight but still allows the tray to slide.
I just finished replacing the sliders for the battery compartment drawer. Here's what I did.
The existing slides that were installed were 12" long. These slides are supposed to support about 150 lbs of batteries and the drawer. I don't know if the slides were of the "over extendable" style or not (before I broke them) that would slide out more than 12", but no matter what, it wasn't nearly enough to fully open the drawer to easily get the batteries out. Thinking a longer slide would allow for the drawer to extend further before "over extending" the main slide length, I installed 18" slides. I contacted Accuride and their customer service was good, however, I just didn't get answers fast enough to be able to purchase from them. I purchased slides from a company called Ovisonline.com
18" Over Extension Drawer Slides, 130 lb., 04932-018-02500
I cut holes in the back corners of the battery drawer for the slides to extend thru. The area behind the battery box is somewhat protected with other objects, so the slides themselves shouldn't get damaged. If you do this, you may want to spray the rear ends of the slides that sticks out of the battery box with a wax type of undercoating that needs to be applied every couple years to protect the ball bearings in the slide from rust.
This was a quite easy replacement. Remove the drawer slide base from the battery box and cut off the old slides from the base and drawer, grind down the old welds smooth and tack weld the new slides in place. I placed quarters between the drawer and slide base so that there was clearance between the two pieces to slide easily.
