Yep, Sensfan, true, but in reality it is a bit misleading as I mentioned switching to a specific pad style that is very likely different than what is causing the issue and not just "change the pads and rotors". That is the way it is on the internet, and I am very skeptical of what is said also, especially when it contradicts what lots of shops still say so not a big deal.
It is good you can handle it with style of driving, but beware the odd place where it might not. You also have the 6 speed that gives you a lower second gear, I think, so more braking than the 4 speed.
I go more towards the pants and suspenders type solutions so want to have a lot of cushion for the unexpected things. We did hit what I think was the hardest to keep the brakes cool descent that we ever were on. We could smell the brakes at the bottom but still no issue braking or judder.
Smoky Mountain parkway east to west was where. Bad combination of steep descent, lots of sharp curves, and with a fairly long distance between the curves. The distance between the curves lets you get going fast enough to need considerable braking to make the curve unless you go very slowly on the straight section, which is hard to do and really irritates the 50 vehicles lined up behind you as you go very slowly.
At the bottom we saw quite a few vehicles with smoking brakes at the visitor center that is right at the bottom.
