Broken flexplate #2 requires a new transmission
Original Member Title: Broken flexplate #2 requires a new transmission
A member reported a second flexplate failure at 75,000 miles in a 2016 Pleasure Way Lexor TS on a 2015 ProMaster 3500 chassis, following the first failure around 50,000 miles; both produced ticking at idle that disappeared with revving or under load. The dealership found worn alignment dowel holes in the transmission case and required transmission replacement, resulting in an $8,600 repair with a two-year transmission warranty, rather than the quoted $2,400 flexplate replacement.
The...
reilym
Mar 24, 2019
113
MI
Bringing this post over from the Promaster Forum.
I am replacing the flexplate for a second time in my 2016 Pleasure Way Lexor TS (2015 Promaster 3500 chassis). First one at about 50K miles in 2024 ($1800) and this one at 75K miles was to be $2400, a 50% increase in 2 years. Work was warranted for 12 months/12K miles, so zero help there. In both cases, the symptom was a noticeable ticking noise at idle that disappeared when the engine was revved or under load.
After the transmission was removed, I was informed by the Chrysler dealership that because the alignment dowel holes were "wallowed out", I would need to replace the transmission. $8600 later the I have the van back, along with a 2 year warranty on the transmission. The tech described to me that two steel pins hold the aluminum transmission case in alignment with the iron block and the soft aluminum is the wear point. He also said that he's only seen this frequent flexplate failure on RV's, speculating that it's the added weight stressing the drivetrain. That said, it's hard for me to understand how there is any movement once the engine and transmission are bolted together.
At 67 years old, I've driven hundreds of thousands of miles in numerous vehicles with aluminum transmissions bolted to iron blocks and I've never had to replace a flexplate until this Promaster. Obviously, there is an engineering problem here. As others have pointed out, part of the blame may be the lightweight flexplate. My broken one weighs in at 4 lb. 3 oz. and appears to be pressed out of 12 gauge steel. Seems like this might be a little undersized for a 5 ton vehicle. You can see the cracks in and around the mounting holes in the attached photo.
It seems unlikely that the dowel pin holes would wallow out unless the transmission wasn't bolted securely to the block. Nor would an understrength flex plate cause damage to the locating holes in the transmission.
The flex plate cracks are likely an effect of misalignment from messed up locating holes, causing the plate to flex slightly each revolution.
Unrelated: I once bought a car where the previous owner pounded the dowel pins flush into the block to make it easier to install the transmission. He sold it because it kept tearing up the flex plates. :rolleyes:
The only way I can imagine dowel pin holes are wallowed out is from mis-alignment of the transmission to block, or from loose transmission bolts holding it to the block. If this was the same shop who did the work the first time, you may want to bring it somewhere else and have them check the tightness of the transmission bolts, and at a minimum, ask the shop who did this for a detailed explanation on how the dowel holes allowed out.
…The tech described to me that two steel pins hold the aluminum transmission case in alignment with the iron block and the soft aluminum is the wear point. He also said that he's only seen this frequent flexplate failure on RV's, speculating that it's the added weight stressing the drivetrain. That said, it's hard for me to understand how there is any movement once the engine and transmission are bolted together.
If that were true, than why did Dodge give it the GVWR that they did?
First I can say I am not familiar with this particular joint.
But, could the attaching bolts between the engine and transmission be "bottoming -out" or interfering with something before they are fully torqued. I am suggesting that the transmission is not tight to the engine. Does wear show on one of the surfaces?
It is a bit hard to understand how the dowel holes in the transmission get worn as there should not be any motion there even possible unless there is some kind of misalignment in the first place or the bolts were loose or undersized for the clamping force needed.
These locations need to be very close to fit at all as the pins should be very little clearance to the hole in the transmission and able to prevent the rotation of the trans to block. The crankshaft end, pins and bore of the bellhousing of the trans all need to be concentric and very square to each other when put together.
It could be as simple but not noticed things like the threaded holes in the block not being deep enough or with machining chips in them so the bolts don't fully clamp the transmission.
It is also very common, but less so in modern vehicles, that the block or transmissions aren't parallel do to machining errors. When the transmission is in place and torque converter bolted to crankshaft, the trans to block bolts should be able to be loosened and the trans pulled back a little bit while still on the pins without much issue and gap from the trans flange to block should be the same on both sides at the pin area. It used to be very common to need to shim the area between the block and trans to get them parallel.
A new trans may fix it OK, but with two failures, it does make on wonder what is going on because not many of them seem to do that flex plate breakage, especially that fast. If the issue was with the trans, you will probably be fine, but if it is the block it may return, I think.
Going back to the shop for a retorque of the bolts might be a good idea to make sure it stays tight, just like we have to do with aluminum wheels on hubs.
Just google "chrysler flexplate failure rate"your not alone
