Camping World Sunlight Van One aka V1 [ hands on review ]
After a 7 hour drive (including fuel and lunch stop), I finally visited a dealer that had a Sunlight Van One (SV1). I had been considering if the SV1 was low enough in price, I could use it as the basis for making changes and enhancements rather than buy a more expensive Class B already setup like I would prefer. Without any ill will intended, I can only say do not even consider purchasing one of these. Yes it is the lowest MSRP price (or lowest I know of) in a Class B. But virtually everything you may have seen wrong in the two part video made by another person on You Tube at some other dealer is exactly the same issues I saw.
I will not recite them all or add any pictures here that are not already shown very well in that You Tube video. It was just shocking to see wall panels that flexed and bowed out. Cabinet doors not aligned well. Cabinet interior panels falling away from their double-sticky back tape position. Control panel wiring exposed due to dividing panel already fallen off. Forward bathroom wall bowed out again due to double-sticky backed tape no longer adhering two surfaces. And why oh WHY would anyone use this type of tape in a range of temperatures and humidity to adhere anything, especially with more than a few inches of this tape?
Continuing on; looks like no insulation behind the walls but that is only where I could see and that was because the wall panel was already separated; I didn't have to pry anything to look at this. I can literally go on and on about the worst quality assembly and quality control I have ever seen. But one more item I must comment on that is also in the two part You Tube video; the shower curtain track -
All you have to do is stroll into the bathroom and without even trying to seek out issues, the ceiling mounted track for the shower curtain looks like it has stress cracks in it. When our eyes focus on these cracks, they are not cracks at all. It appears that a prototype was hack sawed at key points to fit the track around the ceiling. And that prototype should have been translated into a manufactured casting or pressed into shape to provide a satisfactory product, not a hacked (literally) piece of metal with rough enough edges to draw blood. Ok so you would have to stick your fingers up there to draw blood but no kidding, I was able to split surface skin on a finger (did not draw blood) by examining how rough and crude this track really is.
Could I move the curtain around the track without issue? While the track makes a path like a mild roller coaster for the curtain to travel, it wasn't terrible but it certainly took a few stops and pulls to get the curtain around. How long this track will last? With most of the supportive metal of the track hack or band sawed through, certainly not long. If nothing else, a total embarrasment to show your van to anyone else that has any other brand in the USA that is made here.
I suppose the one thing in the You Tube pair of videos that I did not see was the backward gravity waste pipe. This van actually had the 3 inch waste pipe properly bracket-attached. What I wanted to see however, was how the waste system worked since there is ZERO documentation online, at least the last time I checked. Erwin Hymer Group of North America certainly does not have to post PDF copies of their Owner Manuals online but I do wonder why they have not, or have not yet. Enough time has past since they landed on the shores of North America.
Beyond information that would help sales by having having these manuals online as a simple information source, it is a wonder that nobody has posted review videos that enlighten prospective buyers on the features of the SV1.
So how does the waste system work? I can tell you the three people involved in sales I have talked to had no clue. As it turns out, the four page (well, three pages with a basically blank rear page) states it correctly once I crawled under the SV1 to see how it was plumbed. The brochure says the SV1 has a "12 V macerating toilet and gravity dump".
Assuming that a macerator is built into the toilet per the brochure, the path out of the grey/black tank looks straightforward as long as the pipe is hung properly. There is a gate valve to open but the curious thing is the end of the pipe has a garden hose cap. I'm not sure gravity alone will get the macerated waste down several feet of 3 inch pipe and then squeezed out through a garden hose sized hole without some mechanical assistance.
Sales guy had no clue. This SV1 looked like it had storm troopers through it enough times to be missing any documentation, unless the office had it stuffed away somewhere. The sales guy wasn't taking this to heart so I did not push the topic.
Oh and one more thing. Go look at one of these and do a simulated run to the bathroom to do a #1or #2; your choice, and you have family or friends in the van. Actually this would be a good exercise for an executive from EHNG or CW to try. Just try to close the door panels of the bathroom for privacy. If your of good humor, you might find it an amusing puzzle. If your lacking humor and patience, the complex and odd door panels will test your frame of mind and body that needs to complete a pit stop.
Conceptually the SV1 can be spot on for an entry level Class B for camping or light travel use for one or two people. Execution of the concept in my opinion needs to have been done better. I do hope CW and HYMER make a Rev B of this with the same idea, just done to a higher standard.
Gene
