Those side ports are still a perfectly good way to bring in portable panels. What matters is what sits on the other end of the wire, because that decides what kind of panel kit you can plug in.
There are two common setups. In the first, the port runs to a charge controller inside the van, and the controller feeds the house battery. Then you want plain panels with no controller of their own. In the second, the port runs straight to the battery, and the panel kit has to bring its own controller, either built into a suitcase panel or as a separate box. Either way, a controller has to be somewhere in the chain. Victron's wiring guide puts it plainly: a solar panel connected directly to a battery will damage the battery. The controller is what turns the panel's higher voltage into a safe charging voltage and stops charging once the battery is full.
To find out which one you have, trace the cable from the port and look for a small box marked solar or PV, often near the battery or converter. A quick multimeter check at the port with no panel plugged in also helps: if you read close to battery voltage there, the port most likely goes straight to the battery.
If you end up adding your own controller, a few things worth knowing:
- MPPT or PWM: in Victron's worked example, a PWM controller harvests 81 W from a 100 W panel at 25 C, about 19% less than an MPPT. PWM is fine for one small, warm panel. MPPT pulls ahead when panels are cool, in low light and with partial shade.
- Check two numbers on any controller: the charge current it sends into the battery, and its maximum PV voltage. The panels' combined open-circuit voltage has to stay under that. A typical 12 V panel is around 22 V open circuit.
- Fusing: Victron calls for a fuse between the panels and the controller, and the controller-to-battery wire should be fused close to the battery as well. Size each fuse to protect the wire it sits on.
- Set the controller for your battery type.
Also worth a look at the plug on the port and the size of the wire behind it, since the panel kit's connector has to match and a long, thin run loses some of the power.
