2014 Chevy Roadtrek 190 Popular. The high mount brake light housing has two holes melted through the plastic housing over the bulbs, and the integrated rear camera is not working.
Took it apart today. Brake lights appear to be working normally. That’s the good news. The housing is integrated in the factory black plastic over the rear doors, so I assumed it was a Chevy part. Wrong! Dealer says there was no rear camera, and it’s a Roadtrek part. Dead end. To make matters worse, I managed to drop the housing, and it was so brittle it broke into several pieces.
Anybody know where Roadtrek sourced the replacement brake light housing with integrated camera mount? They must have ordered it from some aftermarket supplier.
Failing that, I am going to remove the rear camera and install an OEM Chevy brake light. Hoping it’s better quality than whatever RT used, which was not sealed against water intrusion.
