This post describes a fix to my mild brake judder/vibration issue that started on my 2006 Roadtrek 210P. I had replaced the front brake pads and rotors, and rear pads in 2014 at about 50,000 miles with Hawk brakes. That improved my braking tremendously and eliminated my juddering/vibrating on hard or long downhill braking. But in 2021 at 130,000 miles I noticed some slight juddering occuring on hevy/hot braking. I had read about the issue with uneven brake material transfer to the rotors. THis is what causes juddeirng in most instances in my opinion. Many like to blame the rotors warping, but I do not think that is the problem on our heavy Chevy Roadtreks. I had read about a guy with a BMW with this problem, and he sanded his rotors pretty heavily and it fixed his problem. I thought I would try that before looking at getting new brakes. It has been a year and 10,000 miles since I did this fix and the brakes still work perfectly. This writeup has more in it than just the brake work.
I had interacted with Booster on this and had planned to post earlier but never got to it. He mentioned it in this post:
https://www.classbforum.com/forums/f5/brake-problem-rt-05c210p-1875.html
Roadtrek Brake Service, Rotor Refinish, May 2021
Just got back from test drive and bedding the brakes. Followed Hawk procedure: 10 stops from 35, 3 stops from 45 mph. I never fully stop though. 15 minutes driving to cool off.
Not even a hint of wobble or vibration. Just a dead straight stop,
Here is my theory of what caused the previous wobble. The front rotors had developed an uneven burnish or transfer of brake material to the rotor. So the brakes grabbed slightly unevenly. This uneven braking coupled with the poor steering system design and some cumulative looseness from the individual parts: tie rods, idler, pitman arms, idler bracket. Yet after a few stops the wobble decreased or even went away. So somehow the rotor evens itself up from heat or brake material transfer. I think that most “warped rotor” situations are not warped at all but uneven rotor surface condition.
Theory on why this uneven rotor surface occurred: I tend to baby my vehicle and brakes. Anticipate traffic signals, engine brake, etc. This is evident by the pads lasting so long, with 65k on these and plenty of pad left. My other cars usually have minimal brake wear also. I need to rethink my braking habits. It would probably help to do some heavy braking occasionally. Perhaps do a bedding once a month too.
Measurements:
Both front rotors: thickness (1.495”), thickness variation (0.001” max), runout (0.002”). Hawk rotors.
Left rear rotor: thickness (1.123”), thickness variation (0.001” max), runout (0.004”). Original rotor.
Right rear rotor: thickness (1.128”), thickness variation (0.001” max), runout (0.006”). Original rotor. A little over spec (0.005”) but I didn’t think it was worth the effort to remove and index or turn.
Front Hawk pads: 5/16” thick
Rear Hawk pad: 3/16” thick
I measured front runout after reinstalling the rotors. Got the same runout numbers.
Measurements:
