Berniewolff said:
I have recently bought a 95 Roadtrek on a chey body.
I plugged the shore power in and I am hearing a clicking noise and a Hum coming
from the converter. Is this normal??? The microwave and tv works and the
lights are also working.
Thanks for your help.
Bernie
As markopolo says, hum yes/maybe, click probably not.
Was anything else on, like the water pump? Mine groans on occasion when I switch it on,
but it's not really a clicking noise, more like a steady groan. It's near my converter, so
that's why I mention it.
If googling doesn't find you anything, I'd send a note to Roadtrek Service and ask your
question, they often have the answer, or a good idea of who else to contact. :think:
service@roadtrek.com - Include your year and model and VIN number with your question.
You could also ask the question of the converter manufacturer. That should be on the face
plate or cover, or listed in the owner's manual (I downloaded a copy and it's actually in
section "J" near the end of the online PDF version) as a "Magnatek converter" based in
Kokoma, IN. (If they still exist?).
Or, contact Best Converter and "ask Randy". They list many types of converters and seem
to be pretty good at support and replacement parts supply (if it comes to that :shock: )
http://www.bestconverter.com/
Good luck.
UPDATE: I googled "magnatek/magnetek converter clicking noise" and one or two hits mentioned
the relay which automatically switches the RV 12V power source off the coach batter
ies and onto
the converter for 12V when you plug in to shore power or use your generator (if you have one). They
suggested the relay can get corroded over time and sometimes sticks and keeps trying to switch
power sources, unsuccessfully. I think it also is supposed to allow the coach batter
ies to charge when
plugged in to shore power, and then switch away from them when they are fully charged.
It's also supposed to switch back to batteries when you unplug from shore, or shut down your genset.
According to some blogs, it can be fixed/cleaned up if it's not too far gone,
but that would be a diy project that could be dangerous if you're not well versed in RV electrical systems.
It may be that the relay needs to be replaced if that's the problem.
Another possible diy, but with the same caveat.
Again, good luck.
