A member with a 2026 Coachmen Beyond 22RB reported that the house 12V system and Vega touch screen would not power up while the chassis battery still worked and the van remained drivable. The RV is only six months old and under warranty, but the member wanted to check whether it might be a simple user or setup issue.
Members suggested starting with basic shore-power checks such as the plug, GFCI, breaker, surge protector, transfer switch, and RV breakers. Other suggestions included cycling...
Members suggested starting with basic shore-power checks such as the plug, GFCI, breaker, surge protector, transfer switch, and RV breakers. Other suggestions included cycling the battery disconnect switch, considering a stuck disconnect or bad house battery, resetting the Xantrex inverter, and recognizing that lithium systems can be quirky. There was some disagreement about whether solar would still charge if the batteries were disconnected, and no final repair or confirmed cause was reported.
