Ha. You’re right 5 months would not be enough. We drove the van home to Massachusetts during a low 30F day in February. That’s 7 months. After we got it home, we had some of the coldest days of the winter. We comfortably slept in it at 10 degrees when we got it home.
We had some below 0F days that followed. The Lithium battery weighs 125 pounds. I’m not going to take that out. Instead, I just kept the van heated to 50.
My plan going forward is to keep the interior warm when lows are below 0 are expected I can plug in to 110 household and get enough power to run the heater.
I know of others who do nothing for the cold and have not had a problem with the lithium. There are others on this site that clearly have better electrical knowledge whose opinions I would respect.
For me, I really wanted the larger battery and targeted a minimum of 6Kw. The 310 AGM was not enough. The represents 150Ah usable.
We added a Starlink Standard that consumes 35W. That comes to about 70Ah over 24 hours. The rest of our usage is about the same. I can estimate the AGM would provide a day for our needs before the generator would be needed.
There is a hybrid option to pair a 330 Ah Lithium with the generator. That would effectively double the storage. I think it’s a dealer add-on. If you can get by the extreme cold storage.
At first, I considered buying the AGM model and doing an upgrade to Lithium because the 20K markup for Lithium seems like a lot (it is). To their credit, it seems Coachmen uses good components. Victron, Lithionics, and Xantrex seem like respected names. The retail on the Lithionics was unexpected. In the end, I paid for their expertise.
When looking at online listings I always see a couple dozen AGMs and less than four Li. I don’t know how the business model works. I suspect the dealers are putting an AGM on the lot and having the Lithium’s built to order. If you drill down on the listings, more than half of the Lithium’s are very likely not in stock.
We ordered one the first 2026’s. It was built to order and took 4-5 months to be delivered.
