Moving the holes for the lower arm are what I am doing on out 07 right now, delayed by my surgery but will get back on it in June. Ours has a factory error that moved the right front wheel nearly 3/4" to the rear so more caster without moving it forward would hit the wheelwell.I replaced all the upper and lower control arm bushings on both sides with ACDelco gold. With no one able to get this into alignment I have to suspect something must be wrong and only thought I have at the moment is frame is out of wack.
Shop # 5 or 6 mentioned moving the holes in the lower control arms. At the time I did not understand what he was talking about. Tech #8 the one who did not speak English indicated that the upper control arm is not long enough.
You may not need to move yours, and it is a big job do do well.
New upper arm bushings are what I am talking about, but not stock ones. Camber bushings have the hole offset to give the arm more adjustment.
You have lots of positive camber on it now, more than needed by lot at .3*.
It would be best to see what the caster comes out at is you use that .3* to get more caster, allowing the camber to go to zero degrees, straight up. My guess would be you could get a couple of degrees of more plus caster that way. Add camber bushings that give 1.5* and you could be decent on both settings.
All the older body on frame stuff settle, and back in the day they would pull them out, but it very hard to find someone to do it now unless the frame is out of the van which is a huge job. That is why camber bushings exist.
