Brian123
I'm strongly considering a 2021 Zion Slumber after seeing a used one at a local dealer. Compared to other Class-Bs, this model seems to offer a lot of features, all be it, with some compromises. Such as just enough lithium/inverter to run the AC for a short while, but nothing as robust as a 600-800 amp hours systems. Plenty of storage, but at the of cost visibility. Small front lounge while someone sleeps, offering lots of flexibility. Basically, it checks enough boxes that I can I'm okay with compromises or weaknesses.
I'm almost at the point if I should negotiate a lower price at this dealer, but I do have concerns and questions, some maybe only owners can answer (of this model or similar)
BASIC SPECS:
CONCERNS AND QUESTIONS:
FIREFLY CONCERN - GLITCHY SCREEN?
The screen kept glitching back to the home-screen while trying to use other pages. If I navigated to another page, like temperature control icon or the gear icon, and it would flash back to the home screen. Sometimes after a couple seconds or almost instant. When I did manage to shut the AC off, then it seemed to stabilize a bit at least. (I can share a video if requested)
AC FOR PASSENGERS DURING DRIVE?
Can you easily run the AC off the Lithium while driving? Will the still charge during the drive as well, so you are not too low later?
PASSENGER COMFORT / MOTION SICKNESS?
I hear the rear bench can be bouncy, cause motion sickness. For the sideways couch, is they even more of an issue?
LOW-MILEAGE = HIGH-RISK?
With only 2600 miles on a 2021 van, likely expired Roadtrek warranty, is that a risky situation? Did the owner have enough time to really get all the bugs out?
LITHIUM CARE / TEMPS?
It's hard to find info on this. Since the 2 lithium batteries under the coach, exposed to outside temps, did Roadtrek include heat pads? It's not a 4 Season Van, but if you winterize, you do want the batteries safe.
SLUMBER = NO EXHAUST FAN OR VENT BATHROOM
HAS THAT BEEN AN ISSUE?
While it has a large sky light that can open considerably, do you lose the ability to effectively change the air and cool the van without using AC? (I noticed the newer Zion Slumbers have a much smaller skylight too)
What about restroom venting?
POP-TOP = FUTURE LEAKS AND DETERIORATION?
Class-B vans are great for their original chassis body, but a Pop-top adds a larger weak-point on top, which long-term could cause issues. Is that a valid concern to have? Both the lid and the fabric on sides?
INSPECTION:
I hope to lock for a 3rd Party Inspection in the SF Bay Area, no matter how much the sales person talks up their inspection process and that you don't take ownership until you are 100% satisfied (minus some cosmetic issues).
SAFETY FOR REAR PASSENGERS:
Anyone have concerns over the rear seat safety, especially the side bench with lap-belts? Not sure how great I feel putting someone in a spot like that, then again, it may just not be any better for any configuration.
What is a reasonable offer?
$100k is a bit over my initial target, even if it is a genuine good deal. Though, at this price range, there are many other models to consider, such as a used Travato 59GL or Pleasure-Way Lexor FL/TS 2020(+-), which are often in the 85-95k range - if you keep an eye out.
Is it realistic to attempt a low offer on a used vehicle at a large dealer? More like $85k, maybe in $80k, while possibly too low, leaves room for them to counter? Again, this is a dealer, which might attempt up-sales and fees. Or maybe I just offer what I'm willing to pay and hold my ground during negotiation, for better or worse? It's been on their lot for a month now, which seems really full at the moment, plus foot traffic seemed low. Then again, I don't know what is normal, but only a 1 or 2 other the last two Saturday's I've gone mid-day.
Condition:
It looked practically brand new through, minus a few tiny details. Zero odd smells, even after baking under 83 temps and about 101 inside (according to the Firefly panel). Didn't feel as hot as some of the other vehicles under the sun. Maybe the pop-top with mattress does help insulate a bit, and/or the light sandstone exterior. Salesman was able to turn on the lithium batteries and inverter and fire up the AC. AC wasn't too loud for being on high, I could talk fine. The AC had a few random noises here and there, but I assume that is normal.
Thank you for any answers, feedback, and suggestions.
BASIC SPECS:
- 2021 (Both Roadtrek and Chassis)
- Current Price: $99,998 at a dealer (Recently reduced $5k after sitting a couple more weeks)
- Miles: 2,600
- Extra Options: Sumo Rear Spring System | Induction Stove
- "Looks" brand new (inside out)
- Sideways power sofa with lap belts
- Note: This unit is so new, despite being there for like a month or more, it doesn't have photos online and was currently in line for what I assume was an inspection (key was in the service area), plus it was waiting behind another new arrival, a 2018 Zion SRT with 10k miles for $73k, which we couldn't get the batteries to work. Rear sofa bed was a bit limiting for someone 6' 2"
- If you have to go, is the smell going to last longer and be much worse for others in the van? Maybe this is always a problem, even with fans and vents?
- What about time to dry after shower?
INSPECTION:
Condition:
