JonMN
- Joined
- Jan 16, 2022
- Posts
- 212
I have a 250 amp alternator in my Ford Transit based Coachmen Beyond. This feeds the coach AGM battery via a 150 amp fuse from the access point.
At the moment I have a BIM-160 that handles charging. I am considering replacing the 330AH AGM with a 300AH lithium.
The question is this: What would be a safe DC-DC maximum if I did not want to overly stress the alternator? I have searched quite a bit for opinions, and they run the gamut from just 30 amp to 60% of your alternator capacity, which would be a whopping 150 amp.
Here is my thinking: My coach air conditioning is a DC unit. I measured the draw at it's in the range of 64 amps when the compressor is running. On hot roads, it's nice to be able to run the coach air as well as the chassis air. I also have a DC refrigerator, but that takes less than 5 amps. So I was hoping to use a DC-DC of at least 70 amps so that I would not be losing ground with the coach air conditioner on.
Does 70 amp DC-DC sound safe? Would 100 amp DC-DC be out of line given the 250 amp alternator?
