exilio said:
In Photog's long thread about his suspensions tweaks (
http://classbforum.com/phpBB2/viewtopic ... 6&start=90 ) he says the generator has to be moved back 2" to get the Hellwig sway bar to fit -- but in that thread they're talking about a 2009 Chevy Roadtrek............
The reason for moving the generator, is because Roadtrek mounted the generator so close to the rear axle. Then they ran the generator exhaust between the generator and the axle. This leaves no space for the swaybar.
There can be a couple solutions:
1) Re-rout the exhaust, and check to see if the swaybar will fit.
2) Adjust how the generator is mounted, to gain an extra inch, and see if the swaybar will fit.
If you read the thread about my suspension, you can see that Booster & I used different approaches to the swaybar issue. They both work. I really like Booster's solution.
On my van, the swaybar we added is a Ford part. Advanced 4WD, in Salt Lake City, added the necessary brackets, to mount the swaybar, and leave clearance for the generator. I plan to have the generator exhaust re-routed, and then have the swaybar mounts changed, to tuck it up higher.
If you have a Dodge, their rear overhang is much larger than the current Chevy's. You may have plenty of room for the swaybar.
Drive your van down to a junkyard, take a few measurements across your frame, then go into the junkyard and see if any of the factory swaybars will fit. You might have to go out and measure your van again, as you learn what fits where. Then just have the fab shop make the necessary mounts, and install the swaybar. If that does not work, you will learn how things fit, and you should be able to choose the correct Hellwig swaybar for your van.
One last point: The swaybar ends do not have to mount forward of the axle. It works just as well, to have the ends pointed to the rear. You just need to have a swaybar with the right shape, so the bar does not interfere with the drive shaft (large curve in the middle of the bar).
