markopolo-ClassB
I replaced the failed water heater in my camper van this weekend. It should have been an easy job because I chose the same model number as a replacement. The job was difficult in my unit because I could not just slide the old water heater out from the outside of the van. The exterior hole was smaller than the water heater. So it had to come out from inside. When this van was built the water heater was installed first then the wall panel, then the seat/bed etc. Everything was cut tight so I had to remove some of the structure but ended up cutting a bit of the interior wall panel to make it bigger instead of removing the whole wall panel.
Old water heater had a flange around the perimeter - the new one doesn't have that flange.
Anyway, it is all finished and tested now. No water leaks, no propane leaks and it fires up on the first try.
In the US the water heater would cost $300+ and in Canada more like $500. That got me wondering if it was even needed for us. It is needed for comfortable showering but I doubt I'll shower in this van. It is easy to heat water in a kettle for doing dishes and washing up etc.
So, at $300 to $500 would you do without a water heater in your van or is it worth the cost to you?
