The model is RM 8550 Dometic 3 way in a 2012 Pleasure Way. It was only running a short time on propane then clicking again so I pulled the burner cover, turned it back on and the burner lights then after a few seconds there is a 2nd flame that pops up from the burner tube (not sure if that’s what it’s called). As you can see from the pics it burned through the wire insulation. I’m not sure where this extra flame is coming from, a leak?
Is there a way to shut the gas completely off to the fridge while still being able to use it on shore power and still use the propane cooktop?
