Members shared long-term frustration with the Dometic 3-Way RM8501 fridge shutting off unexpectedly when running on propane, especially at higher elevations. After years of troubleshooting and unsuccessful repairs, the original poster discovered the root cause was a faulty propane regulator, not the fridge itself. Replacing the regulator immediately resolved the issue, even above 9000 ft.
Other RVers confirmed similar experiences, noting that while stove burners might light normally, the...
Other RVers confirmed similar experiences, noting that while stove burners might light normally, the fridge can still fail if the regulator pressure is just below spec. Some suggested lighting a stove burner first after storage to help propane flow, but emphasized that persistent fridge shut-offs often point to regulator problems. Cleaning or replacing the thermocouple was also mentioned as a possible step, but regulator replacement proved to be the most effective solution for recurring issues.
