youngnretired
It's the beginning of March, so that means Roadtrek repair season is soon coming upon us! It was too cold last year when we returned from our route 66 trip to do any repairs when we returned home in mid November, but work will soon begin once it warms up a bit.
The portion of the original old and bumpy route 66 roads in Illinois weren't too kind to our refrigerator, and coupled with likely overloading the lower door shelf at the beginning of our trip yielded a broken shelf "tab" on the inner door panel at the end of the door that's opposite the hinges. This tab both supports the shelf, and holds the lower shelf to the inner door panel. I've searched for a replacement inner door panel but have not found any, so likely we'll have to repair this tab. I assume that this is a simple JB Weld fix, but wanted to solicit other ideas from those who may have had to do this before and if they've found a better product or ways to improve this area.
Also, since our lower shelf is cracked, a replacement will be ordered soon. Does anything think that there would be any benefit to using the ends of the broken shelf and (plastic) welding these to the top of the ends of the new shelf so that the shelf would now be supported by two of the tabs (per shelf end) on the inner door panel, or would this be a waste of time and effort?
