electrical panel - 95 roadtrek versatile 190
In mine (2002 Chev 190 Popular) it's behind a brown panel below the driver's side
bed. It has a small screw/twist knob to open the outer panel to access the fuses
and breakers. It is attached to the converter/charger which is actually underneath
the bed itself.
According to the owner's manual for your model, your converter charger is in the
dinette seat box on the driver' side. Although I don't know for sure, the fuses and
breakers (panel) will probably be near it, probably on or behind some sort of removable
door or panel.
Chassis fuses are most likely under the dash near the steering column, but some may
be located under the hood in the engine compartment.
and VOILA! Thanks so much for the help! Don't know what I would have done without the forum!!
