Express Van Upgrade Cooling System With a 2 Row Radiator
youngnretired
Jun 8, 2025
375
Green Bay
After purchasing our 2008 Roadtrek 210 (2007 Express 3500 Chassis) and learning that these rigs run hot from others on this forum, I decided to make some upgrades. This posting is about these upgrades. Thanks to booster for his write up of the changes that he made for the idea. I didn't use the same radiator that booster did for two reasons. Booster's write-up was based on using a late 90's radiator from a big block express van. This radiator didn't have the oil cooler in the incoming water side of the tank, and it also seemed that this radiator was going out of production because it was becoming extremely hard to find. I do want to acknowledge booster and his assistance with this swap over. There were several private messages between us that all happened behind after my initial install and to get things right.
Booster's original write-up: Big radiator for later Chevies?
My search showed that a radiator from a 2002 Express 3500 with a 6.5L diesel had 2 rows of cooling and it also shared the same dimensions as the single row radiator that fits for the 6.0L in our van. 2002 is the last year for the 6.5L diesel engine option in the Express van. This radiator had both the trans cooler and oil cooler in the tanks, but it didn't have the tall neck with a radiator cap on it. So this required either a change of the coolant jug to one that is pressurized with the radiator cap and pressure release on the coolant jug, or adding an in-line radiator fill cap. I went the pressurized coolant jug route with this build. Since the coolant jug is pressurized, it's part of the cooling system, and there needs to be means for returning coolant to the system from the jug for proper coolant flow. I originally added a "T" connection to the lower radiator hose like it would have been for the 6.5L originally, however, subsequently I found that this didn't work. All my experience with cooling systems is from small and big block Fords and Chevys and old 1.6L VW diesels with the thermostat at the top of the engine. The 6.0L has the thermostat at the bottom radiator hose on the water pump. The radiator hose connections on the diesel radiator are also larger than that for the 6.0L engines, so adapter's were needed to change hose sizes. The coolant jug came with a 20PSI cap, so I changed this out with the factory 15PSI cap.
At one point I did find a radiator listing for a newer/different express van with 2 rows of cooling, but I don't currently have that part number, and I believe the hose connections were different size than what I had researched with the 6.5L radiator. I was way too many hours in my research and about 30 minutes from ordering parts, so I didn't want to start the process over. I was going to change the fan clutch to a severe duty clutch, and after I got into doing research, I decided to also change the water pump since there was no real additional work to change the pump out from what had to be done to access the fan clutch. I also wanted to add a factory style external transmission cooler to the van.
Parts list:
Radiator: 2002 Express 3500 6.5L diesel - Spectra Premium CU2043
Coolant jug: 2007 Express 3500 6.6L diesel - Dorman 603-239
Lower radiator hose: 6.0L Gates 23127 and I used pieces from the diesel upper hose for the connections to the radiator. The 1 row radiator has the quick connect lower hose connection and the 2 row version does not.
Upper radiator hose: 6.0L Gates 23383 and for the 2002 6.5L, Gates 22360. Same as the lower hose, you could probably do this cheaper with a section of 1 3/4" radiator hose and cut for what's needed.
Radiator hose reducers: ICT Billet on Amazon. One 1 3/4" to 1 1/4" for the upper hose, and one 1 3/4" to 1 1/2" for the lower hose. IF you have access to a lathe, you could also turn down a solid piece of aluminum or aluminum schedule 40 pipe to make a reducer instead of purchasing them.
Radiator rubber saddle mounts: Dorman 926-276
Water pump: Gates 45010
Fan clutch: Hayden 2786 severe duty
Approx 2' of 3/4" heater hose to connect the "Y" on the heater hose return hose to the coolant jug, and approximately 12" of 3/8" fuel line to connect from the coolant jug to the hose barb on the radiator.
A 3/4" barbed to 1/2" male pipe fitting, a double ended female 1/2" pipe to 1/2" pipe coupling, and a 3/8" barbed to 1/2" male pipe fitting to connect the steam/throttle body coolant line to the 3/4" barb on the radiator.
3/4" "Y" fitting to plumb the coolant jug into the heater core hose return line, Amazon "Feedun" 226061
Thermostat: Gates 34198
Belts: The long one, Gates K060930 and the small one, Gates K040378HD
Transmission fluid return line: Dorman 624-123 (connects rear port on the transmission to the drivers side of the external cooler).
Transmission fluid line to external cooler: Dorman 624-966 (connects lower radiator port on the radiator to the passenger side of the external cooler).
Note that the above cooler line from the transmission doesn't work for vans 2009 and newer as, at a minimum, the connection on the transmission is different.
External transmission fluid cooler: Dorman 918-290
Tool to remove/install the fan clutch: Lisle 36mm wrench 43390, Lisle 43370 wrench handle assembly and you'll need an air hammer tool.
I really didn't want to pull the doghouse to undo the transmission tube mount from the back of the head that boosters original post mentioned that's needed to get the upper radiator shroud out from under the hood. After trying to get the upper radiator shroud out from under the hood for 20-30 minutes, it appeared that if I got the radiator out, the shroud may come out without trouble. It was in this process that the oil fill tube became dislodged from the valve cover, so I pulled that out. I was able to get the radiator out leaving the upper shroud in the van pretty easily, then the upper shroud was a cinch to pull out after that. The installation is reverse, install the shroud, then slip the radiator in. I was able to get the old radiator out by myself without scraping the fins on the radiator, but the new one I had a friend help. I also placed cardboard over the engine side of the new radiator before installation. However, I believe there was enough room where the lower ends of the radiator shroud wouldn't have hit the radiator, but I'd add the cardboard to be sure.
Installation was pretty straight forward except for three items.
1. I originally added a "T" in the lower radiator hose for the coolant return from the jug. This resulted in some issues that took a while to iron out. I looked at the 6.0L in my 09 GMC 2500 truck, and they have a pressurized coolant jug where the return line from the jug goes to a "Y" in the heater hose return line to the water pump. This is the hose that's right behind the thermostat housing. This heater hose is 3/4" connection at the water pump, heater control valve, and now the pressurized coolant tank for our 2007 Express van. I was hoping I could use a factory "Y"d heater hose setup from a truck, but each of the three hoses were different sizes, so it was much simpler to get a 3/4" "Y" and use 3/4" heater hose. I purchased several "Y" connections and chose the one I felt would be the best to cut into this short hose. Note that this hose is pretty hard to get off the heater control valve as I didn't want to break anything. Also, some vans I looked at in the junkyard didn't have an accessible heater control valve and the hoses to the heater core were different/longer, so at some point GM may have changed the design and moved this valve to inside the heater box. I have no idea how anyone would access the upper connections on these longer hoses to add a fitting, but since my heater control valve was accessible, it was ok. It was very difficult to get two hands in there to do anything though and this took a while. I also had issues with those constant tension clamps GM uses and gave up on using them. I used the regular screw style clamps and this went much easier. Note that while I had the "T" in the lower radiator hose, I found that one of the constant tension clamps wasn't holding the radiator hose reducer as tight as it should have, so it leaked. I replaced the small side clamp on the lower hose with the screw type clamp.
2. When I went to install the new fittings in the radiator for the trans and oil cooler lines, I discovered that the oil cooler ports on the 2 row diesel radiator were much larger than the old radiator. Apparently the diesel uses 5/8" oil cooler lines, while the 6.0L uses 1/2" lines, or course, with different size fittings in the radiator. The 6.5L uses a 5/8" quick connect oil line to 1/2" pipe thread connector, and the 6.0L uses a 1/2" quick connect line to a M20-1.5 thread connector. I tried to find a 1/2" pipe thread to M20-1.5 thread adapter, but that seems to not exist. I brainstormed with my neighbor, and we come up with a solution. He took a short 1/2" pipe nipple and machined a bit from the inside of one end to slip over the end of the old stock steel fitting, and TIG welded them together. If you want to purchase new fittings and have all this done before you pull the radiator, the fittings that fit the 2007 6.0L gas are Dorman 800-607. Prior to calling my neighbor, I researched all the Dorman fittings I could find and ordered two of them that I thought may work. Their comparison is in the pictures below. It's correct in that it has the 1/2" quick connect oil line side and 1/2" pipe thread, however, the quick connect end is slightly larger than my original one's. So, I don't know 100% if the conical seat in the fitting is correct, or if the slightly larger quick connect side won't hold the oil cooler line in properly. These came late in the game for me to spend much time on them as I had already installed the radiator by the time these fittings that may have worked arrived.
3. When I filled the radiator, I filled it 100% thru the upper radiator hose like we're supposed to do, then I added a bit to the coolant jug. With the "Y" in the heater hose, this may have caused a bubble in the heater core because when I initially started it up, I had zero heat from the heater. I ended up removing the 3/8" line from the radiator barb to the coolant jug and with the engine running, used compressed air at the coolant jug (after reducing air line pressure to 15PSI) and then this forced coolant into the heater core/pump and I started to get coolant flow out of the 3/8" air bleed line from the radiator.
I purchased a Scangauge III and drove the van prior to doing these changes. It was upper 80's temperature and I drove it to the other side of town and got off the highway then started driving thru stop and go traffic (mostly slow speed without much stops). When we exited the highway, the transmission temperature was 180 and went up as we drove thru town. Max transmission temperature ended up at about 201 when we hit the highway to head for home. It's a short trip back home on the highway, so it didn't really cool off from there. The radiator temperatures were right around 200 on the highway and went up to about 205 while in town. After these changes were made, driving with similar upper 80's temperature, when I exited the highway, coolant was 198 and transmission temperature was 149. The van runs at 196-198 on the highway or in town. When you stop at a light, the temperature climbs to 205, but as soon as you hit the gas and moves more coolant, it goes right back down. The transmission temperature slowly climbed up to 183 while driving thru town and didn't cool off on the short trip on the highway back home. With the external transmission cooler, there is a 20+ degree temperature drop in the transmission fluid, and with the additional cooling capacity of this radiator, under most normal circumstances, it keeps the temperatures under 200.
external trans cooler
shroud removed
new water pump
pictures of the old and new radiators
upper radiator hose compare (6.5L on the left and 6.0L on the right)
upper radiator hose with adapter
a used heater core valve assembly from a parts van
heater hose "Y" fitting
radiator reducers
oil cooler line fittings at the radiator, new are the brass and the steel are the originals
oil cooler original fitting revisions
radiator installed
possible oil cooler fittings
coolant jug install. I replaced the red heater hose in the previous pictures with new black hose. I did take a short piece of the red hose and slit it longways and clamped that over the top of the heater hose as it went past the AC system components. It was close to touching, and with the additional hose around it, any rubbing and it shouldn't wear thru.
Selection of "Y" fittings that I purchased to see which fits best. I used the one in the upper left.
I have been in on this update since early on, and it actually was a big benefit to me, along with another discussion going on that had a comment about going to the larger big block radiator. I currently was fighting with the larger radiator I have in the van as the drain valve had quit sealing and no repair/replacement parts are available. I was looking for a backup new radiator in case I was not able to fix the older one. As the OP mentioned, the big block radiators are disappearing, but I got lucky and found a new unsold (allegedly) one at a clearance part place in a small midwest town. If I had not found one, I may have been doing the same switch to diesel as the OP. Not all of the big block radiators only had the transmission cooler, though, as the ones I have have both coolers in it, as did a few other brands, but most did not.
That said the OP's diesel radiator is a viable option for those that want a bigger radiator, but does require either changing it to a pressure overflow system or adding an upper radiator hose fill neck/pressure caps.
The OP had seen several other pressure tank setups in other vehicles, but as mentioned they all had the thermostat at the outlet to the radiator at the top of the engine so somewhat different. I happened to have the short duration of production engine in the my 96 Buick. 5.7L gen2 small block with reverse flow cooling. It was the first to move the thermostat off the high point of the engine to engine side of the lower radiator hose, AFAIK. Those engines had the pressure tanks and steam tubes that are necessary to get the steam out of the top of the engine, just like the 6.0 needs. The thermostat location causes the lower radiator hose to often not see any significant suction from the pump so it can mess up the flow hose from the bottom of the pressure tank. Moving it to return from the heater fixes that as it goes right to the pump and flows normally.
The OP is seeing slightly higher running temps than we do, probably do to thermostat differences and not an issue as long as it controls within the safe range. We also do not use the trans cooler in the radiator at all on ours, relying only on two large in front of the radiator external coolers that run on their own thermostat to prevent overcooling in cold weather. We see normal water temps of 190* +/-3* and trans temps of 175* to 185* on a Scangauge. Both will go slightly above 200* on long climbs but under 205* almost all the time.
It will be interesting to see what the transmission temps run for the OP when in the mountains, as that is normally a bigger issue with the 4 speed trans Chevies than the water temp. The OP added an addon cooler of moderate size and basic tube and fin design, which will help, as will a probably tighter fan clutch he used. It wasn't mentioned how the OP plumbed the cooler, as in radiator first then cooler or cooler first then radiator. The order can make a difference in both the cooler and radiator temps, as well as the temp the transmission sees. We didn't get a full fix of the trans temp issues until I reprogrammed the transmission shift and lockup points.
Bottom line is probably that using a diesel radiator from the previous generation may be the only way to get more radiator cooling in the Chevies going forward, as long as they are still available. Of course a full custom radiator could probably be made to fit but it would very expensive to buy.
I used the factory style lines to the new external cooler (from Dorman). One line is a replacement for what's on these from the factory that don't have an external cooler, and one is new. The new replacement line takes the return from the external cooler back to the trans, while the totally new hose takes the fluid from the radiator out to the external cooler. So, as the factory would have originally plumbed it if it had a factory external cooler, to the radiator first, then the external cooler next. I would actually like to run a little cooler than 180's for trans temperature, so I'm currently thinking about adding yet another external cooler that is the smaller rectangular style fin coolers. It is highly unlikely that we will be going anywhere in our RT in cooler weather, except at least for this year returning home in mid November from a route 66 trip. I will have to winterize while on the road and I'll find out. R
If anyone needs a radiator that booster used in his conversion, I did find one in all my search that was supposed to be available thru walmart.com. I believe it was the Spectra CU1787 or an equivalent.
The transmission temp is going to be a bit hard to control whenever you have the cooling in both the radiator and extra cooler, or just the radiator. A large part of it is because the trans cooler is on the cold end of the radiator so the water temp can vary by a very large amount depending on how close to max capacity the radiator is running and how far the thermostat is open on the engine. I chased that a lot. Based on our 190, and you are going to be at least as heavy, most likely, you probably will be getting a hot transmission in the mountains sometimes. Unless the trans is reprogrammed you need to hold quite high rpm to get the converter to lock up. The shift and lockup points are shown in reprogramming discussion on the forum. IIRC you need to be over 3500 rpm in 3rd gear to lock the converter, even though the engine will pull a steep grade and much lower rpm. In Rocky mt Park there is a long steep curvy grade that has a 35mph speed limit and it will pull 3rd gear on at under 3Krpm. It won't lock however because of the low rpm. Even in 2nd gear you may not lock. The charts show for sure as it has been a long time since I did those changes.
The top inlet to the radiator for the water will be running near what the Scangauge is telling you it is although you have to measure the inlet end fins to see and that is inexact. The transmission end can be much cooler than that depending on the the trans heat generation from the engine and how much water is actually flowing in the radiator. If the cool end of the radiator is running 210-220* you might actually heating up the trans oil. If it is running at 130-150* you get a lot more cooling.
Personally, I am OK with 180* for a transmission with DexVI in because the VI gives much more top end heat range without problems and warmer oil usually lubricates stuff better. The old days of life of a trans being 1/2 at 170* compared to 130* or whatever are gone, I think. Numerous posters have said their Scangauges are reporting 210* normal running temps in 6L90E in the 2010 and up Chevies. Our 07 was the first year, I think, that the vans came with Dex VI.
I'm going to monitor things for a while as the additional external cooler is an idea and it's WAY down the list of things to do. In any case, the external cooler will certainly help over what it came from the factory with, so should the additional cooling in the radiator. My old 84 Chevy 1/2 ton ran at 130-140 trans temp unless I was pulling a load with it.
I have heard that a lot from the pickup people and can see why they question it. "Most of the parts are nearly identical, so why do you get hot and I don't"?
I think the big deal is the location and shape of the engine compartment. Air in capability looks to be close the same, but the air out of the compartment to the ground is huge in the pickups compared to the vans. If the air can't get out, the air isn't going to come in the front.
Here's a couple pictures of the baffles I added to aid with cooling. While at a local pick and pull salvage yard, there were two express vans that had these baffles in them, so I got a set. I believe they were both 2010 and newer vans, although I can't verify that. These were screwed to the AC condenser mounting brackets, which were plastic. Our 2008 Roadtrek 210 popular had the AC condenser replaced a few years ago and the the mounting brackets on ours are metal.
The baffle is held on by two screws. To mount them, I removed one of the 4 screws holding the mounting bracket to the actual condenser, and drilled a new hole for the other. Since the screws that came with these baffles were long, I used #8 washers (3 on the screw that screwed into the one mounting screw hole location, and 5 on the screw where I drilled into the condenser mount) to ensure that the back of the screw didn't rub on the vertical portion of the condenser.
Condenser mount removed screw and drilled hole in the condenser mount. This is the drivers side. Note that after this picture was taken, I had to flip this, remove the lower screw and drill a hole towards the top of the mount, as the baffle ended up being mounted too high. Drivers side and passenger sides are flipped and I started with the passenger side.
I have found that baffles are a very good thing in our Chevy, and I even took it a bit further by plugging all the bypasses around the radiator and into the engine compartment. All the gaps around the sides., and the bottom sealed also, even along the top edge and latch opening.
Air that bypasses the radiator obviously doesn't cool anything, and it also pressurizes the engine compartment a bit which reduces the radiator airflow because the radiator/condenser/coolers all resist flow. Air that goes out the bottom into the negative area reduces the negative pressure that pulls the air out of the engine compartment. I found ours had noticeable improvement once you get to 30mph.
Both coolers are for transmission and the thermostat is under the bottom baffle. The external coolers are the only trans cooling and oil cooler stayed in the engine.
attachment.php
attachment.php
The GMC grille has over 60% clear area and the Chevy only 45% so that also helped.
attachment.php
Youngretired. Has this improved the cooling at all? I ask, cus I just installed the same cooler and really didn't see much difference.
If you are talking about the transmission add on cooler, I am not surprised. Early on we added a factory cooler that was then a different style and it did not help.
If you look at my pix above, even those two huge, fin and plate, thick coolers can't keep the transmission in the 4 speed vans cool whether through the radiator or not when you get to the tougher climbs where the converter is not in lockup.
We did not get good cooling until I changed the computer programming for shift points and converter lockup.
Booster, I have read almost all of the ways to cool a trans. In short, what tool do you use to change shift points?
I have extensive threads on the tools and programming software on this site. They include screenshots of the software programming so you can see where they are stock and what I went to.
The main tool is to have a "tuner" like an HPtuner unit. Not cheap but worked well with some learning. I had an advantage because I had used tuners on past hotrods so less learning curve. I will try to dig up some the links to those threads, which are long but spell it all out fairly well.
Here is a link the start of it all for me and programming. Some stuff has been refined since and others have preferred somewhat different settings based on their driving preferences, and tuner lets you do what ever you want.
Programming link
I believe this has helped with the transmission cooling. Whether it does a perfect job, I don't know, but it MUST add some cooling to the fluid. I was only able to run the van once after we got our Scangauge to display transmission temperatures before I embarked on this changeover. It was upper 80's and driving on the highway to the other side of town, the trans went up to 180. Going thru town, the trans went up to 205ish. It's a short drive from the east side of town to our house on the highway, so I wasn't able to observe any cooling going on the highway. After adding the cooler, I did the same route, although it was 2-3 degrees cooler, and the trans went up to a max of 183 while in town. So, based on these numbers, I got 20+ degrees of cooling from it.
Last week we took it for a ride to the lakeshore to get out and do some things for the day. The temps were in the upper 70s and we were on 2 lanes, so doing max 65MPH. The trans got up to a max of 173.
I had planned on adding yet another external cooler, but decided to concentrate on other things before we have to leave on our trip. We leave in 10 days. I have all the parts to add the second cooler (except for the cooler itself) and an idea of how I'll do it, but that will have to wait until next year, or not at all. I'll know more on how this goes as we traverse the country thru all sorts of weather. It'll be in the 40's when we return home and upper 90's in locations on the trip.
We found that with the big coolers and radiator we were fine around town, but were never really bad anyway but when we hit a second gear climb that speed limit made it impossible to get the trans to lock we quickly got to 225* on the trans and that was in cool air. High temps will hurt you some, particularly in the city traffic, but it is steep hills that don't let you get to locked converter speeds is very much harder to keep cool. We found it impossible even with fans, big coolers and big radiator.
Take a look at the programming link I posted above and see just how fast you need to be going to get the converter to lock as it is very, very surprising I think.
This trip will be a learning experience on trans temps. We don't have any hills of any decent size around here, so there's no way to test anything around here except high temps, highway and slow driving in town stuff. I'd like to keep the trans below 225, but don't really know how realistic that is. My old 84 Chevy half ton hauling a 7000lb load would only get over 200 trans temp when I was in town and literally hit every light as it was going red. That had a big 10,000lb external cooler on it though. This newer technology stuff is all different to me, but my 09 GMC 2500 runs in the 180's doing 80 MPH when it's 85 out pulling our 3500lb popup. That's my only other reference for trans temps for things newer than mid 1980's except for my brothers 2019 F150 3.5L max tow that runs pretty much at 195 no matter what we did with it. But, I think that's thermostat controlled fluid temp, not just what it cools down to with full flow thru the system.
After installation of the new cooler, I drove round trip to death valley, approx 125 miles. The outside temp got up to 114. The engine temp raised to about 230 and trans stayed around 200-205. That was leaving death valley going from sea level to approx 2000 above sea level.
