markopolo-ClassB
Edit: I found the PCM (Powertrain Control Module) in my GMC van and have updated this topic.
Engine as a generator............
What are Fast Idle and PTO?
http://www.gmupfitter.com/publicat/bull/bull64.pdf
The mod discussed in this topic is more than a single speed fast idle. It can give you 3 additional idle speeds. It gives you PTO like idle speeds without having an actual PTO unit. Newer vehicles can have variable idle speeds. More on that later.
Why would you do it? It gives you:
Increased Air Conditioning for stationary operation.
Increased Electrical Output for stationary operation.
Increased Vehicle Heating for stationary operation.
My 1997 GMC Savana diesel idles at 624 RPM. I can run rear window type air conditioner off my inverter and the van dash air on "max air" blowing cold and the idle goes up to 651 RPM. Link: http://www.classbforum.com/phpBB2/viewtopic.php?f=12&t=2286&start=8#p12016
However, I've read that it is better for the engine to increase the idle to near 1,100 RPM if you want to idle it for extended periods.
The fast idle mod on my van can give you up to 4 idle speeds:
Normal idle (624 RPM for my van)
1070 RPM
1360 RPM
1600 RPM
Power Take Off (PTO) and Fast Idle both allow for elevated idle speeds to allow the engine to perform a desired task. In the past, engine speed increases were often a simple mechanical adjustment. With the advent of electronic engine controls, engine speed is now controlled by engine electronics. The Engine or Powertrain Control Module must now be used. Various combinations of wiring and programming changes may be required to implement these functions.
Fast Idle is sometimes called High Idle. It can be ordered on some vehicles as RPO UF3. It causes the engine to go to a single elevated speed for increased output from normal accessory drive components. Examples are increased voltage from the alternator or increased cooling from the HVAC compressor. Fast Idle can also take advantage of increased base engine heat output for fast vehicle heating.
PTO’s (Power Take Off’s) are used when hydraulic fluid is needed to do the work. It can be ordered on some vehicles as RPO PTO. The PTO unit itself typically mounts to the transmission or accessory drive. Notes: GM does not sell PTO’s as factory equipment; an up fitter must add them. Accessory Drive mounted PTO’s will invalidate the GM Accessory Drive Warranty. PTO differs from Fast Idle by offering a greater degree of control. These controls include multiple or variable engine speeds and increased turn on/off logic. PTO has more complex wiring for the Upfitter to install than Fast Idle. Some functionality comes standard from the factory in the PCM.
source: http://www.flashoffroad.com/Diesel/fast ... stIdle.htmflashoffroad.com said:Most manufacturers recommend around 1100 RPM for extended idle periods on diesel engines to prevent carbon deposits.
1070 RPM
1360 RPM
1600 RPM
