Fiamma F45 awning missplaced the tiny bolts
THEBRAIN
Dec 1, 2015
264
AL
05 Pleasureway Lexor Chevy Express 3500 I removed the shade awning I think it is Fiamma F45 an missplaced the tiny bolts an nuts that attach awning to the two roof surports. anyone know the bolt/nut size? thanks for advicing
I have a Fiamma awning on an 02 Roadtrek if we are talking the same thing there are 3 brackets on the side of the RV to attach it to, the center bracket has no fastener hole and the front and rear have 2
small hole. On mine the fastener was a pull rivet, 3/16 if I recall correctly.
Ours is a Roadtrek but I think the same awning.
The awning tilts into the top of the brackets and bottom slides in. We had 3 small sheet metals screws up from the bottom the went through the bottom of the bracket and into the awning to keep it from sliding back out and the awning falling out.
I have a Fiamma awning on an 02 Roadtrek if we are talking the same thing there are 3 brackets on the side of the RV to attach it to, the center bracket has no fastener hole and the front and rear have 2 View attachment 2441755small hole. On mine the fastener was a pull rivet, 3/16 if I recall correctly.
you know I spent over 3 hours removing those 6 bolts, thats probaley why they came up missing so I could avoid fighting it again.
I have lots of rivets most are 1/2" grip also 3 differnt size rivet guns. revits should hold it in place fine the upper hook is doing all the surport.
an if I need to remove drilling should as heck won't be long.
thanks JJrbus
I was thinking about using the self tappers was concerned the shape tip of screw ripping the fabric.
I have a feeling I may need an assistant to place it back on those brackets. I'm gonna have to scrape my plan on relocating the brackets outward.
remember I wanted to install a roof rack bolted to the roofs dip rail.
now I maybe able to slide the whole awning forward a tad to have enough room for the roof rack brackets. thanks Booster
Both Pleasure-Way and Fiamma are very responsive. I’d call PW if it is the bolts mounting the awning to the van or Fiamma (in Orlando) if it is part of the awning.
I decided to use 3/16" revites. here's my attempt at contacting Fiammoma
Fiamma​
32K people follow this
Sports & recreation
Apr 15, 2026, 10:36 PM
05 Pleasureway Lexor Chevy Express 3500 I removed the shade awning I think it is Fiamma F45 an missplaced the tiny bolts an nuts that attach awning to the two roof surports. anyone know the bolt/nut size? thanks for advicing additionaly it took me over 3 hours to remove these bolts is there a larger bolt available that wound'nt take so long to replace the awning?
Apr 16, 2026, 7:14 AM
Hello , Thank you for contacting us, we forwarded your message to the Technical Team, will reply as soon as possible.
Mon 6:29 AM
HI, Could you kindly send an email to service.export2@fiamma.it regarding this matter, they can assist you properly. Thank you
Mon 12:57 PM
what happened to you forwarding my message?
5:59 AM
Hi there! Our technical team would love to help you out with this directly. Could you please send them a quick email at service.export2@fiamma.it? Our technicians don't have access to social media chats, and we want to make sure you get the best support possible from the people who know the product best!
Write to Fiamma
