For Sale: Camper conversion 1993 Ford E150 Econoline Cargo. 4.9L inline 6 Engine. 4x2. $22k OBO
IslandCruiser
May 21, 2021
1
Coupeville, WA
Located just north of Seattle on Whidbey Island
Ready for your next adventure?
Custom Econoline built to explore. Mechanically sound, well maintained and drives excellent - very reliable. Most work/maintenance was performed within the last 500 miles. Clean title, straight body (one dent behind passenger rear wheel, covered by side ladder). Comes with receipts and service manuals.
Van Exterior highlights
  • BFG KO2 Tires 265/75R16 (5)
  • American Racing alloy wheels (5)
  • ALUMINESS Weekender roof rack with ladder
  • ALUMINESS Rear swing-out tire carrier + VECTOR Accessory mount
  • ALUMINESS Side ladder
  • WATERport Weekender 8 gallon roof rack mounted water tank (can be pressurized with air compressor)
  • THULE Van bar door locks w/keys (side & rear)
  • KC HiLite off-road top lights (x8 front rack mounted)
  • KC HiLite flood lights (x4 mounted on rack sides)
  • Late model Econoline grill w/ amber LED lights
  • Aftermarket black headlamp assemblies w/ LED light strip (6000k LED high output headlights)
  • New Third brake light housing assembly
  • New Rear License plate housing / handle assembly + Rear camera for mirror
  • Painted Slate Gray, OEM Jeep Wrangler color (7 years ago)
*Original color was gray, so door jams/engine bay etc match the exterior*
*Most interior and exterior light bulbs have been replaced with LED bulbs*
Van Engine highlights
  • 4.9L (300ci) inline 6 cyl. engine with C6 transmission (hard to find combination)
  • OPTIMA yellow top main battery w/ aluminum battery clamp tray
  • Custom 200amp 3G alternator w/ overdrive pulley
  • All new complete oversized power & ground wiring
  • Remanufactured HD starter
  • Spark plugs
  • Wires
  • Ignition coil
  • Summit Racing complete distributor assembly (incl. distributor cap & rotor)
  • Ignition coil
  • Bosch 02 sensor
  • ICM (ignition control module)
  • OEM remanufactured ECU/ECM (Engine Control Module)
  • Ignition switch
  • OEM factory gauge cluster with tachometer calibrated for larger tire diameter (original cluster w/o tach included also)
  • Current overall mileage 195,55X. New gauge cluster ODO is at 161,66X miles
*All new engine gaskets & vacuum lines*
  • Refurbished OEM throttle body
  • MAP sensor
  • IAC (idle air control) valve
  • TPS (throttle position sensor)
  • PCV valve
  • Valve cover grommets (PCV/breather)
  • Air filter
  • Crankcase breather filter
  • Windshield wiper motor
  • Entire window manual regulator assembly (left/right)
  • Window rain guards
  • Rear pop out / vent window
  • Door gaskets
  • Complete turn signal switch assembly
  • Pioneer Bluetooth head unit
  • Rockford Fosgate 3 way 6x8” speakers
  • LED 1080p Rear View mirror w/ wired camera (front & rear recording)
  • Black soft dash cover mat
  • Cordura seat covers
*Complete and entirely new fuel system*
  • Steel gas tank 35 gallon (rhino lined exterior)
  • Complete Walbro drop in fuel pump assembly
  • Locking gas cap
  • Fuel filter
  • Fuel filler neck
  • Fuel lines
  • Fuel tank straps
  • Ceramic coated OE fuel rail
  • New FPR (fuel pressure regulator)
  • New Bosch Injectors (not refurbished, brand new)
  • EGR & Smog Pump delete, done correctly
  • Cylinder head plugged and air pump + rail removed
  • Custom EGR valve block off plate + exhaust manifold EGR plug + mount
  • Modified alternator bracket w/ smog pump portion removed (better belt wrap on alternator pulley)
  • Ceramic coated Intake manifolds (port/gasket matched)
  • Ceramic coated OE exhaust manifolds
  • Ceramic coated aftermarket Y-pipe
  • Complete new exhaust/muffler system
  • AC works but needs a recharge (r134a)
  • Radiator + cap
  • HD fan (7 blade) + clutch
  • Hoses
  • Thermostat housing (ported)
  • 180F High Flow Thermostat
  • HD water pump
  • Temp sensors (on thermostat housing & engine block)
  • Front brake calipers, pads, rotors
  • Hydraulic brake lines
  • Brake booster
  • Master cylinder
  • Rear drum brakes completely overhauled
  • Parking park cable line & housing
  • Fresh oil change (Rotella T6 w/ motor craft filter)
  • All new fluids
  • Transmission serviced 10k miles ago
  • MOOG complete steering linkage bar assembly (greasable drag link, tie rods, adjusting sleeves)
  • 1.5" lift w/ KYB off-road HD shocks
  • Polyurethane radius arm bushings
  • Polyurethane body to frame bushing (front and rear)
  • Front sway bar bushings
  • Remanufactured steering gear box
  • Remanufactured Power steering pump (OE Saginaw)
  • Front wheel bearings
  • MOOG HD greasable u-joints
Van “House” highlights
Interior
  • Sleeping platform
  • 2 large drawers
  • 2 cabinets
  • 1 side storage
  • Refrigerator slideout with tilt and ARB power outlet
  • Full size propane storage cabinet
  • LED overhead dimmable lights
  • MOLLE panel board (mounted on engine cover)
  • Insulated w/ vapor barrier + sound deadening
Electrical
  • 200amp Lithium Battery
  • 1000w Inverter with two 110 outlets and remote control
  • RedArc 1225D DC-DC battery charger with Solar MPPT + remote connections
  • Renogy 100amp Solar suitcase
  • Victron BMV-712 Smart Battery Monitor + Shunt with Bluetooth
  • ViaAir Air Compressor with 5 gallon tank (mounted underneath cab)
  • LED lights
  • Sirrocco II 7” omnidirectional 3 speed 12v/24v fan
  • USB outlets
More pictures --> FS-1993 Ford E150 Campervan · Jul 20âââ22 ð¸
