Very nice work. Congratulations
We too built out our camper ourself during covid and 2 years later everything has worked out great. We still have a couple of minor finishing things to do. A quilted headboard is an addition we would like to add and our garage slide needs the edge banding replaced since it has become chipped from dragging to many things over the edge but we are still 100% happy with the build and after using it for 2 years there is truly not a thing we wish to change from the original layout plan if we were to do it over again. The only bit of wisdom I can give is it will take many more hours than you think initially to build but the end result is worth it. We had to wait for some pieces due to supply issues during covid so there was some build on further then remove to put in missing equipment and reinstall a second time. The re&re was life but I wouldn’t want to be doing this if I was manufacturing vans as it was a unnecessary waste of time. I can live with it on our van but sure wouldn’t recommend if you were building vans commercially.
