InterBlog
RV LIFE Pro
First how to post pictures on site. Second, best way to block heat\sun in windows. Have heard silver reflective stuff bad for window seals??? Thanks!
Your first question's answer depends on your interface. On the desktop version, you can either use the paper clip icon which will probably allow you limited space only, or you can use a third party platform like Imgur to create a photo stash from which you can then embed photo frames (I do the latter). I don't use a mobile app for this forum so I can't comment on its function.
You'd get a better traffic pattern if you'd post your second question in a topical portion of the forum, probably in the General Discussion Area. Although with a quick glance, I didn't see a thread devoted to it.
We certainly have a detailed thread about blocking heat on Air Forums (Airstream Class Bs, but the heat blocking predicament is common to all Class Bs irrespective of brand). It discusses window coverings both exterior and interior, as well as insulation, reflective roof coatings, tints, and other topics. You can see that info here.
