fresh water pump location
irishnut
Jul 20, 2012
4
question! where is the freshwater pump on 1997 rialta RD? is water required in the tank in order for the pump to turn on?
I have the HD & my pump is under the rear seat-bed. The pump should be located next to your water tank.And no the pump willl run with out water, I donot advise this the pump could burn out
thank you I found it! problem I have now is the pump switch wil not turn on looking for fuse. hot wired pump and the pump is working fine
rem said:I have the HD & my pump is under the rear seat-bed. The pump should be located next to your water tank.And no the pump willl run with out water, I donot advise this the pump could burn out
