2018 Roadtrek SS-Agile Class B RV
$129k OBO
On 2017 Sprinter Chassis - Short wheel base
39,300 miles
Many upgrades
Excellent mechanical and physical condition
Tires - 1350 miles (replaced May 15, 2021) with OEM Kumho Cragen
Professionally maintained per Mercedes specs by Mercedes Dealers, a local garage specializing in Sprinters, and by the original RV sales and service company - all maintenance records available.
Includes:
- All original equipment
- Galley with propane stove, sink, combo microwave/convection oven, storage cabinetry
- Sofa that electronically converts into a king sized bed
- Wet bath
- Hanging wardrobe
- Leather interior upgraded at factory
- Side and rear door "no see-um" screens
Extras and upgrades from original spec
- Exterior silver color
- Upgraded dark cabinetry
- Upgraded dark marble countertops
- Full sized spare
- 400 Wh Lithium coach batteries
- Solar panels on roof to charge coach batteries
- Volt start (engine can be set up to automatically start to keep the coach batteries charges) - excellent if you have pets in vehicle to keep the air conditioner running after batteries are low
Other extras available
- Lets Go Aero - gear basket for hitch (never opened)
- Let's Go Aero Bike Rack - mounts to above basket (never opened)
- Leveling blocks
FULL SPECS BELOW and ADDITIONAL PICTURES UPON REQUEST
Review and OEM pictures at RV Guide - https://www.rvguide.com/reviews/other/2018-roadtrek-ss-agile-review-1743/
Specs from RVUSA site (also includes OEM brochure) - https://www.rvusa.com/rv-guide/2018-roadtrek-ss-agile-class-b-floorplan-agile-tr36523
Engine
Engine - Mercedes-Benz / V6
Chassis Brand - Mercedes-Benz Sprinter
Chassis Model - 3500
Cylinders - 6
Horsepower - 188 hp @ 3,800 RPM
Torque- 325 ft-lbs. @ 1,400 RPM
Displacement - 3.0 litres
Fuel Type - Diesel
Carburetion Type - Fuel Injected
Turbocharged - Yes
Supercharged - No
Transmission
Transmission Type - 5 Speed Automatic
Overdrive - Yes
Driveline
Driveline Type - 4X2
Dimensions
Length - 19.42 ft. (233 in.)
Width - 6.67 ft. (80 in.)
Height - 9.58 ft. (115 in.)
Interior Height - 6.25 ft. (75 in.)
Wheelbase - 12 ft. (144 in.)
Weight
Payload Capacity - 1,500 lbs.
Towing Capacity - 5,000 lbs.
GVWR - 8,550 lbs.
Capacities
Fuel Capacity - 24.5 gal.
Storage Capacity - 289.3 gal.
Holding Tanks
Number Of Fresh Water Holding Tanks - 1
Total Fresh Water Tank Capacity - 30.0 gal.
Number Of Gray Water Holding Tanks - 1
Total Gray Water Tank Capacity - 20.0 gal.
Number Of Black Water Holding Tanks - 1
Total Black Water Tank Capacity - 10.0 gal.
Propane Tank(s)
Number Of Propane Tanks - 1
Total Propane Tank Capacity - 16.0 gal.
Total Propane Tank Capacity - 70 lbs.
From <https://www.rvusa.com/rv-guide/2018-roadtrek-ss-agile-class-b-floorplan-agile-tr36523>
Standard Features
Coach
• Air conditioner - 110V, 11,000 BTU roof mounted
• Awning - 9'10" power awning
• Bathroom - permanently enclosed with shower
• Batteries - two 6 V AGM, 2,400 W
• Detectors - smoke, propane & CO
• DVD Player - 6 speaker home theater surround sound system
• External power connection - 110V/30AMP with detachable power cord
• Furnace - propane automatic, 16,000 BTU
• Home theater system with 5.1 surround sound & dual center speakers with DVD, CD, AM/FM radio, dual use rear speakers
• Microwave oven - 110V convection, 28L/1.0 cu. ft. 1,800W convection/1,000W microwave
• Monitor panel - water, propane & battery charge levels, battery disconnect & generator hour meter
• Propane tank - 60L/16 U.S. gal., 70 lbs.
• Rear power sofa - fabric
• Rear power sofa - forward facing
• "Composite" leather rear power sofa
• Refrigerator - 12V/110V compressor driven with thermostat, 3.1 cu. ft.
• Sewage disposal system - 12V macerator sewage pump
• Stove - propane; two burner recessed with flush cover
• Water heater - propane with bypass, 23L/6U.S. gal., 12,000 BTU
• Water system - on demand 12V with water pump
Chassis
• Airbag - driver, passanger, & thorax
• Alternator - 14V/200 AMP
• Anti-Lock Brakes (ABS)
• Axle - Rear - 3.92 ratio
• Battery - 760 AMP
• Camera - rearview backup - displays on screen of in dash radio
• Climate control - electronic with glove box cooler
• Cooling - transmission oil - external
• Cruise control
• Engine - 3.0L CRD V6 turbo diesel BlueTec
• Headlights - automatic on/off
• Luxury Chassis OEM Package - Luxury Chassis PKG Options: heated driver & passenger seats Airbags: Driver/Passenger Thorax + Driver/Passenger Window multi-function steering wheel w/trip computer, light & rain sensor, pixel-matrix display, blind spot monitoring, collision prevention assist, lane keeping assist Bi-xenon headlamps & headlamp washing system
• Power - 188 HP
• Radio - Mercedes Becker Map Pilot Navigation System with Bluetooth & on-dash keypad, audio 15 FM/AM, aux-in, USB
• Receiver - Class III
• Stability program - adaptive (accounts for load)
• Theft deterrent system
• Tilt steering - tilt and telescopic steering wheel
• Tire storage - rear storage area
• Tires - LT245/75R16E black wall
• Torque - 359 Nm/265 lb.-ft.
• Traction control
• Transmission - automatic 5-speed heavy duty
• Window operation - front door power windows
• Wiring harness for towing - E40 wire harness & 7 pin connector
Options
Coach
• Batteries (2 additional) - 6V AGM batteries 4,800W
• Diesel Alde
• EcoTrek 400 - Lithium Power Modules
• E-Trek Luxury Package - EcoTrek 800 Amp hr. Lithium Power Modules +370w Solar Panel ETLX with Engine Generator + Volt Start Auto Start Battery Protection and Go Sun Solar Oven
• Generator - Onan MicroLite propane generator (2.5kw)
• Generator - underhood engine generator (including B4 extra battery option)
• Portable Solar Cell - 200 Watts
• Screen Package - screens for rear cargo door & enhanced magnetic close screen for side door
• Solar Panels 200W solar panel and charge control
• Solar Panels 300W solar panel and charge control
• Television - 24" flat screen HDTV on rotating bracket
• Volt Start - autostart battery protection technology
Chassis
• Continental spare tire carrier - continental spare tire kit with proprietary effort reduction system (receiver mounted in front of driver side rear door)
• Wheels - 16" aluminum with OEM steel spare tire
From <https://www.fretzrv.com/product/used-2017-roadtrek-agile-ss-1525356-116>
$129k OBO
39,300 miles
Many upgrades
Includes:
- Wet bath
- Hanging wardrobe
- Full sized spare
- Leveling blocks
Engine
Cylinders - 6
Fuel Type - Diesel
Turbocharged - Yes
Supercharged - No
Transmission
Overdrive - Yes
Driveline
Dimensions
Weight
GVWR - 8,550 lbs.
Capacities
Holding Tanks
Propane Tank(s)
Standard Features
Coach
Chassis
• Battery - 760 AMP
• Cruise control
• Power - 188 HP
• Traction control
Options
Coach
• Diesel Alde
Chassis
