apiufb30
Question: My headlights are fluctuating dim and bright when I turn my van on. The battery gage on the dashboard also fluctuates. I have replaced the engine battery and the alternator, and now the coach battery. I didn't realize I was supposed to switch the inverter/converter/charger to "off" or "charge only." So it has been on "auto" this whole time (18months). My engine battery died about four months ago, so I had it replaced. I noticed the headlights fluctuating so I had Autozone test the engine battery and it said it was bad. So they replaced it, under warranty. I turned the inverter/converter,charger to "off." Then they tested the alternator and said it was bad, so I replaced the alternator three days ago. I went back to Autozone because it didn't fix the headlight issue. They checked the new battery and it was at 7%. So we put another new battery in. Then we check the coach battery and it read 6 on the multimeter. So we replaced the it with a new coach battery. This still hasn't fixed the headlight situation. But it did help with the interior lights. So I'm wondering if my isolator isn't working correctly? Or could it be my self resetting circuit breakers? Has anyone ever heard of this problem?
