Jim, welcome to the forum.
YES, I have three suggestions... take a close look at your tires and the date of manufacture.. it's the DOT code... look that up to decipher when your tires were manufactured. If they are more than 6 years old.. look at them closely for cracks. The last thing you want is a "blow out " on a Class B....
A friend of mine with a 210 like yours had a blow out, lost control and damaged his rig..
And, if you get new tires, look into a tire pressure monitoring system.. I have one from Truck System Technologies. Cost was around $300 or so... has wireless sensors telling you the exact tire pressure, etc.
Finally, check your batteries … they typically last about 6 or 7 years if you're lucky.
Good luck.
--Mark
