19Sprinter
- Joined
- Mar 1, 2025
- Posts
- 1
Hi, I have a 2019 Mercedes Sprinter 2500 Cargo 6-cylinder 2WD with ~75,000 miles. I purchased it about a year ago and have put 10,000 miles on it (7,000 in Baja, MX). It ran great the whole time, apart from noting a small oil leak a couple months ago. A faulty glow plug in cylinder 1 was causing the check engine light to come on but I hadn’t noted any other issues. I was driving up a long gradual incline when the van lost power and the battery died. We were towed into La Paz. After seeing two non-Mercedes mechanics (the La Paz MB dealership turned us away and said they don’t work on Sprinters), we got the van running. After running for about 10 minutes, the front crank shaft seal blew and oil dumped out. We repaired the seal, all filters, and performed an oil change. This got it running again, and it ran very smooth upon start up with no oil leaks. We drove it about a mile, and it slowly lost power with significant upper engine noise and then stopped running entirely. After an expensive tow to Mulege, I’m stuck here with a possible blown engine trying to figure out next steps to get the van home to the pacific northwest.
I am looking to get the engine repaired or replaced. If anyone has any experience with something similar or any ideas/suggestions/advice, any and everything is welcomed and appreciated! Please comment and like to boost views—thank you so much!
- Contacted Mercedes Benz Tijuana and they said they will not work on American sprinters.
- Contacted several mechanics in San Diego and received extremely high quotes for a new motor – around $18,000 installed.
