My 2000 Pleasure-Way Excel TD currently has 2 x grp24 lead acid batteries. I want to convert to lithium - LiTime makes a grp24/100ah with cold temp cut-off that should be ideal. I know I will need to change the current converter as it cannot be switched to charge lithium when on shower power or generator. I will also have to replace the battery isolator and herein lies my quandary.
The current battery isolator is a Sure Power 1202. It only has 3 terminals; Alternator, Chassis Battery and House Battery. I plan to replace it with the Li-BIM 225 designed for charging lithium, but in addition to the House/Chassis it includes; Ignition, ground and Sig(nal?).
Obviously House, Chassis, Ground are straightforward. My question is ignition and sig... Am I correct that the sig is indeed "Signal" and would this be the wire currently coming from the alternator? "Wiring diagrams I've found show this to a momentary switch?" Doesn't the alternator wire connect somewhere?
Ignition, I am at a loss unless they just want a hot that is energized when the ignition is on. "Looking at wiring diagrams I think this is the case. .... Or is this where the wire off the alternator connects? "
I have scoured YouTube and forums but every can come up with are newer vans or RV's with no resemblance to what I have. Hoping someone here can steer me in the proper direction!
Thanks!
Thanks!
