How Much Propane Fills 10 Gal Tank?
peteco
Oct 20, 2010
1,067
Hampton
Roadtrek 210P has 10 gallon, 45 lb propane tank spec in the Roadtrek Brochure. Typical fill specs indicate fill to 75-80%.
Has anyone done a fill from empty and how much propane did the tank take?
For my model year, the brochure says it is a 35lb/8 gallon tank. But it is stamped on the tank as 8.4 gallons. I did a fill from completely empty this summer at about 70 degree temps and the overfill prevention device in the tank stopped it at exactly 7 gallons. That seems about in line with the 80 perecent fill spec that you mentioned.
My PleasureWay 08/09 Chevy Lexor says it's a 10 gallon tank. I've never been able to put more than 6 gallons in. I had to replace the shutoff valve and when they refilled it, the invoice said 6 gallons. I only ran out once in 6 years and it hit exactly 6 gallons when filled. It should hold 8, but maybe the manual is wrong. One of these days when I'm under the RV I'll check the model and specs.
