Bruceper
- Joined
- Jul 30, 2014
- Posts
- 678
So I have an idea, and it's not so radical but for me it's different.
I have taken the microwave out of my B and measured the space. There are a few wall type AC units that would fit in that space. They are all 5000BTU units.
We don't live in the B, and during the day we're usually outside under a canopy. I'm thinking it would be more for comfort in the evenings or nights or perhaps to remove some humidity.
We also have no use for a microwave in the B so it's no loss to us.
Details - Behind the microwave is a panel, and right behind that panel is venting. I'm honestly not sure why the panel is there as the microwave should have been vented. There is a plugin for the microwave so the AC unit could just be plugged in there instead.
I would remove the panel, install a screen on the vent and build a vent system using Reflectix to aim the exhaust out the vent so it doesn't heat the cabin. I would also add a drain hose that would be attached when parked so moisture would not collect or run down the side.
I have also considered installing a hard start capacitor just so there isn't a huge drain if we are using power for anything else.
Thoughts? Opinions?
Thoughts? Opinions?
