Identifying and Troubleshooting the House Battery in a Majestic Tour 2
Original Member Title: Help to identify type of house battery I have
An RVer asked what type of house battery is mounted beneath their Majestic Tour 2 and why it appeared slow to charge on household shore power. A member thought its six-cylinder appearance resembled an Optima battery, but its identity was not confirmed. After 48 hours plugged in, the monitor showed full charge, then fell to one light about six hours after unplugging, with appliances reportedly off.
Members suggested checking battery voltage before and during charging to see whether the...
Brewbren
May 17, 2026
26
Albuquerque
So the house battery for my 2013 Majestic Leisure Craft Tour 2 camper van on a 2012 Ford E250 chassis does not look like anything I've dealt with before in the way of deep cycle lead-acid wet batteries (if that is what I have). Here's the worm's eye view of what I'm seeing from underneath the chassis:
So nothing looks like something I've seen in RV or Boat/Marine stores which usually look like larger autombile batteries. I see no way to service it from below, and hope to get some feedback before I try to remove it (bolted to chassis frame) to examine it. Not sure if this is one large battery or two teamed together (never have seen this six cylinder configuration on the left before).
I've had the van plugged into my home power (15A 120V) for 24 hrs and it doesn't seem to be charging. It was working fine a month ago during my travel from Seattle to Albuquerque.
Any sage info/advice would be appreciated. Thanks.
I've not seen the bottom of one of these before, but I think what you have is an Optima battery. They have 6 cylinders as their cell arrangement.
Thanks for this info. I looked those up and that mfr of batteries does seem to match what my 'worm's eye' view indicated. Now I'm hoping that a bit more online research will tell me what I need to know about them (wet cell lead-acid, lithium, other; amperage, charging time, etc.?).
Still not fully charging after about 30 hrs through shore power hook up to my home power.
I'm not 100% sure, but the optima batteries can be installed on their side, and they may be able to be installed upside down. They are not a wet cell type of configuration and because of this, have a pretty universal way of installation.
On the "not charging after 30 hours" part, I'd check the charging side before unbolting the battery.
Start with a meter at the battery. Read it unplugged with everything off (resting voltage is only a rough guide to charge, but it gives you a starting point), then plug into shore power and read it again after a few minutes. A converter that is charging pushes the voltage up noticeably. Progressive Dynamics' Charge Wizard, as one example, holds 13.6 V in normal mode and 14.4 V in boost. If the reading barely moves when you plug in, the battery isn't getting a charge.
If it doesn't move, the usual suspects are the converter's breaker in the 120 V panel, the fuses on the converter itself, any battery disconnect switch, and the fuse on the battery cable. Progressive Dynamics also lists three causes when one of their converters won't fill a battery: a bank too big for the charger to fill in its charge window, RV loads using up the charging current, and solar or alternator voltage making the converter think the battery is already full. That last one is worth keeping in mind with the solar port you mentioned in your other thread, if anything is plugged into it.
If the voltage does rise on shore power but drops right back once you unplug, the battery itself may be worn out, and that's when it's worth pulling it to read the label and have it load tested.
Thanks, CamperVolts. Sorry for the delayed response.
An update: After 48 hrs plugged into home power (15 amp 120 v) it finally reached full charge (4 red lights on monitoring panel) but then discharged down to just one light again when I checked it again about 6 hrs later. Nothing is on (lights, fridge, water pump, et al.) so I'm confident that it just discharged without being drained by anything running or otherwise using chassis battery power. Additionally, I plugged it in again overnight and had the same results: full charge indicated upon removal of shore power (actually, just 15 amp power from my home) and it again was down to just one red about 6 hrs later (just sitting in the driveway with everything off).
If this indicates that the batteries are past their prime and need replacing, so be it. I just want to be sure that I've done what I need to do correctly to charge the batteries. I don't have the tools or capabilities to run all of the diagnostics you mention but have just plugged it in overnight until those four lights lit up. I had driven this down to NM from Seattle in July after buying it there and it worked fine; all four lights would be on after driving a few hours to a new camp site, then it would go down one or sometimes two lights from using lights, ceiling fan, water pump by the time I went to bed, then be back up to all four lights within an hour or two of driving. I never connected to shore power during those two weeks I took to drive back to NM and then started experiencing this after not using it for about six weeks except driving it one time to a mechanic for an oil change and brake check (no camper appliances used).
My next move will likely be to contact a mobile RV mechanic and have them diagnose and ascertain the battery and converter status (I've yet to locate it on my camper). I just wanted to make sure I had done all I could (and correctly!) before I shelled out any dinero for professional help. Thanks again.
Thanks for the update. You charged it the right way: plugging in until the panel shows full is all you need to do.
Going from four lights to one in six hours with nothing on points to one of two things, and there's a free way to tell which.
1. Something is still drawing power. Even with everything "off", a few things stay on: the propane/CO detector, the stereo memory, an inverter left in standby, the fridge's control board.
2. The battery has lost most of its capacity. Lead-acid batteries that sit partly discharged for several weeks can sulfate. They still show full right after charging, because the panel lights only read voltage, but they can't hold it.
The test: charge it to four lights again, then turn off the battery disconnect switch (or take the negative cable off the battery) so nothing can draw from it. Check the lights again after 6 to 12 hours, with the switch back on just long enough to read the panel.
If it still drops to one light, the battery is the problem. Most auto parts stores will load test a 12 V battery for free if you take it in, which is cheaper than a service call.
If it holds, the battery is fine and something is pulling power. That's when the mobile tech is worth it, and you can tell them that up front.
If the batteries are the kind with removable caps, check the water level too. Low water after a hot summer is common and easy to fix with distilled water.
