im a new bee
chrislana
Oct 2, 2023
64
and hope to be here for a long time ,,im also new at class b Tellaro and dont know how to make hot water in the sink i turned on the propain switch ioutside then did several different things with no luck any ideas?
You actually did throw the switch to turn on the heater and not just turn on the propane valve at the tank, right? Just checking.
WOOO no i didnt know their was another switch at the tank ill have to look for it tomorrow
,,,wow i hope thats my trouble ill let u know Thanks for the come bac ,,,,,,ok i cant find another switch im just looking in the wrong spot wear should it be ???
I'm not familiar with the Tellero. Do you have a manual from the manufacturer? Every one of my rigs had a switch somewhere on the wall along with other switches to turn on the hot water heater. (and batteries and inverter and exterior lights... etc)
You should probably also look for the manual to run your hot water heater. The so-called instant hot water heaters are not really instant. What kind do you have? Girard? Suburban? Truma?
I have a Truma its under the side bed its all sealed only a small door to it i looked in there and could not see any switch but the manual shows it has a switch on the truma unit it self
I'm sure that there must be a remote, easily accessible switch on the van interior. Every one of my rigs had one. Your Tellero manual should tell you where this is. Do you have a Firefly? Near it? On the side of a cabinet?
Ok here's the end to this problem RV shop is 1/2 mile from me on the Truma screen i needed to hole the button on hot ..not just touch it ,,there is a switch on the truma but its on all the time and no access to it ,,welllaa hot water in the sink ,,,and a big thanks to you guys love the site ...
