Jfstang
Today I installed an LED light fixture over the sink, and when I turned it on it lit for a second and there was a "ZZZT" and it went out. Now it appears the circuit's dead.
Here is some back story. I have an 05C190P, and last year noticed the incandescent interior lights became warm over time. So I replaced the ceiling lights beside the 3rd seat, beside the bathroom, and over the centre of the bed (the big circular light) with LED's and they worked fine. These LED's were not particular about polarity, the wires were both the same color, so I connected them up and all was good.
Today I decided to replace the light over the sink (not the little one over the stove, that's still incandescent) with a new LED light. This LED light had a red/black stripe wire and a black wire. I connected them to the red van wire and the green van wire (ground). As soon as I turned it on, it shone for a second and went dead. Coincidentally, I found my LED over the center of the bed was now out as well.
But, the overhead LED lights beside the bathroom and 3rd seat, both of those still work fine.
So, I proceeded to RESET the GFCI outlet beside the rear side passenger door, and RESET the GFCI outlet by the microwave. The outlet by the microwave works fine (tested it with an old incandescent nightlight). I tested the red wire for the sink light with my voltmeter, there was nothing there.
Is there a fuse I need to replace somewhere? And can I still install an LED over the sink, or should I just put the old light back in if I get power again somehow?
Thanks in advance, all help is gratefully appreciated.
