shelleybeauvais
Does anyone have a really good connection to the internet? If so, what are you using?
The MIMO antenna you have seems to have been replaced by a newer model but not too many places seem to carry it.
You can purchase it directly from AntennasPlus. They will build you any permutation you want with whatever cable length you specify. They are great. Give them a call.
The issue with gathering opinions on cellular connectivity is that people tend to find something that works for them, and then they begin to assume it's the only option, or the best option, and so they proffer it as such, when with a sufficient number of iterations, what they'd actually find is that their solution is just one option.
I've invested a great deal of research and I've done a large number of trials in multiple areas, including in west Texas and in Canada. What I've found is that sometimes the MIMO works and sometimes the weBoost 4GX works. Where and when they variably work may not be predictable based on "known" conditions. I've had the 4GX work fairly well for 3G and other technologies when the MIMO couldn't raise a signal of any kind. And I've had an "unboosted" MIMO work where the 4GX couldn't find anything to boost. And I've had an expensive carefully-aimed directional antenna fail miserably when a five dollar omnidirectional did just fine. And I've done enough trials to suspect that the outcome is based on more than just my own level of competence (or lack thereof). There are many, many variables that influence cellular transmission and reception.
The best approaches are:
(1) Have a diverse kit that includes all of the technological options named in this entire thread (I'm not the first one to recommend that, as Technomadia originated the suggestion), and
(2) Pray or hope that our public information resources improve going forward. My husband and I thought that we had identified a two-step method for pre-evaluating specific sites for their cellular connectivity potential. What we found was that the published resources don't seem to be as precise as advertised. If you'd like to read about that boondoggle, I've got a blog post here. And I would welcome any criticisms or suggestions on the content of that post, because I still don't have a good explanation for our findings (I gave one example in that post, but the same outcome pattern manifests routinely).
We own a vacation home out West that had a similar problem. The ultimate solution was for the neighbors to band together, build a microwave tower pointed to the nearest available broadband trunk, and burying community-owned fiber from the tower to everybody's property. Not cheap, but property values to houses without broadband are tanking everywhere.On the main property that I've been mapping in terms of its cell potential, I'm at the point where I'm trying to figure out whether I should:
(1) erect an antenna,
(2) erect a cellular antenna plus couple it with my own wireless,
(3) send my air card up on a helium balloon (believe it or not, it has been done successfully by others),
(4) opt for a current-gen satellite solution (I've been advised against it),
(5) wait for Elon to get his butt in gear and surround us with a few thousand next-gen micro-satellites, or
(6) just give up entirely.
Hobbled by lack of 911 service in particular (in a place where rural landlines are no longer supported), the nearest village of less than one hundred souls is trying to:
(7) raise money from us landowners to deploy their own private short-range cellular system which I don't even understand yet in terms of its technology.
I was out there a few days ago trying to suss out what is and is not achievable with MIMO alone. Attached is one of the photos I took and at first glance it looks mildly promising - HSPA+ and -99 dBm. I routinely see worse. But just a few hundred feet from this spot, the MIMO registers nothing at all, whereas the weBoost can get a slow if fairly reliable 3G. But not the LTE that I really need to do my job from this location given that the 3G tends to be too erratic for database interface.
A thank you to those that know more than I and took the time to post. A solution in one location that requires another solution in another location is the surprise to me.
I did look into the Hughes Gen 5 thing. The reviews were not good, one positive out of 500 if I remember correctly. People were most upset about the two year contract to try it and no way out if a week later you found it didn't work for you.
I would like to hear a positive Hughes Gen 5 review. They continue to advertise so surely someone must be getting a useable signal, maybe. Anyone use it?
I just use my phone as a hotspot, but I'm not working online, so it works well enough for my needs. I'm on AT&T with Direct TV Now and HBO. As said above it works well once you finally get it working. LOL It is really a pain to be forced to deal only by chat... no phones. It took me 4 months to get the charges correct. (It was supposed to be $10 a month and they kept charging me $15. AT&T was just as bad to get the billing correct, so perhaps being able to talk to a human doesn't help all that much.Direct TV Now has just added a cloud and you can store programs there for future watching.
AT&T no longer sells hot spots. You can buy an unlocked one and do it, but they are seemingly getting out that concept.
