wincrasher
Considering swapping out my existing PD9245 converter/charger for this:
http://www.amazon.com/dp/B002MW6PHG/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1QIQ697UTEI2K&coliid=IPSKR6NHAB9YW
With this accessory:
http://www.amazon.com/dp/B0074T148C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1QIQ697UTEI2K&coliid=IAGKD4RAX3DJU
I like this unit because it can charge any type of battery - including the lithiums because you can program the voltages for the different charge modes. And of course, the ability to have an inverter on board that could power all devices (except air conditioning of course).
Assuming of that I have room for this device. I've yet to pull up the floor of the closet to see what I'm dealing with. It's a bit bigger than my existing converter.
I assume that the PD9245 is plugged into an outlet which is fed from the circuit panel.
If I understand correctly, the AC for the Magna would be wired between the transfer switch (for shore power & generator) and the circuit panel. Correct?
The PD9245 is only 45amp DC charging. This Magna is 100 amp DC. So were going from about 4 amp AC to around 8 amp AC. Should I be concerned with that? On the control panel for the MagnaSine, there are switches to turn on/off both inverting and charging, so if I "ran out of amps" I could turn off the charger.
Looking at manuals, I don't feel too nervous about this being a DIY project. As long as I size the wires correctly and get the right parts.
Thoughts/opinions? FWIW, I'm not concerned about voiding warranties, so don't comment on that. Thx.
