Keeping the chassis battery charged
markopolo-ClassB
Oct 24, 2006
8,828
New Brunswick, Canada
For the last month or so I've been keeping my chassis battery charged while my van it connected to shore power by using a small jumper cable to connect the two outer posts of my isolator.
I remove it when I use my van.
I don't know if this is a good idea or not but it works for me.
If anyone knows a reason why I shouldn't do this please let me know.
I'll still use my Battery Minders for longer lay ups but this is quicker. I do not use my van regularly so I have to maintain the chassis battery.
I measure 13.4 volts at the chassis battery when connected this way. Your converter or charger has to have a "float" mode if not you could over charge the battery.
strap across battery isolator
I can see no harm to come from this. I do a similar thing to charge my rear battery, charge with negative on chassis ground and positive to the bolt on the inverter which leads to the coach battery.
Thanks
Jack
