Putting in the new front carpet messed up our bubble level setting as it was on the plastic step flange that holds the carpet down. Luckily the lazy way to rereference it that I did the first time is really easy.
First I leveled the van off of the bed, which is the most important to us. The counter will be off a little one way, the frig, another, the floor still another way, as Roadtrek didn't really have a consistent reference.
Here is the area the cheapo bubble level will mount, right behind the driver's seat where I can see it from outside the van or from the seat.
I put a couple of layers of 3 sticky back pads on the back of the level to hold it up above the surface it was going to sit on, but only on one edge. Pick a good location with the release paper still on the pad, where you will be able to be level with the pad on the mounting surface.
Peel off the release liner, and put a volcano of silicone on the middle of the level backside
Just set the level in place with the pads hitting first, and then push it down until it reads level, bedding it in the silicone.
It is nice that this method lets you to very easily mount the level to a place that isn't necessary level with the van leveling.
Total time under 5 minutes, but the van was already level before I started.
