My "water supply question" garnered a lot of views but no replies. Somewhat expected since few would know the Pleasure Way specifics. So I'm shifting to a more general question.
If I follow the plumbing, a line comes out of the FW tank and goes to the water pump. It splits after the WP with a line going to the hot water tank and a line going to the cold water faucet and toilet feeds. Hot water comes down its own lines when HW faucets are opened.
My leak occurs in the very first leg: between the FW tank and the WP. So what I'm pondering is why it would leak there when the FW tank is empty, when the system is no longer under WP pressure, and when I'm flushing the HW tank. I have a ShurFlo pump which has a backflow check valve in the head. Why would water come back through the WP and leak out between the empty FW tank and the pump.
So I know that the ShurFlo is supposed to have the backflow valve. Does a FW tank typically have a valve at its outlet to prevent backflow as well?
If you can offer any suggestions they would be, as always, greatly appreciated.
Thx.Glenn
Thx.Glenn
