See your location is FL...you really need a fix - with all the rain you been receiving. I presume the leak is around the rubber seal of the window; I would try using Captain Claxton's Crack Sealer. You can pick it up in West Marine or someplace like that. It is a milky white sealant..I would put it in where the seal appears loose and will accept it. It flows easy, and finds the leak and seals it. Someone else might have something better, but I used this on an '05 190P with a leak around the 3 Upper Windows - stopped it, and when the material dried, I shampooed the stain away. Ron
