I guess it's in the eye of the beholder, but IMO, considering the level of sophistication of the ARV electrical system design, it seems puzzling that in the event of a BMS shutdown, you have to keep your finger mashed to a reset switch for a couple of minutes to bring the BMS out of a coma.
A seldom needed function? Perhaps for you because you understand your system and don't let this condition arise in the first place. For those less familiar with or less interested in their battery system, or not equipped with an autostart feature, my guess is that it will happen a lot.
In the Etrek, as far as I know, the Roadtrek AGM services no coach loads and is there solely to provide bringing the BMS back to life which apparently it does faster than the ARV system. How it's accomplished is unexplained and in fact, there is no explanation of how this battery is kept charged, i.e. by which alternator or whether it ever sees shore power support.
Since you have the contact, I'd appreciate learning what actually happens electrically in your setup when you press and hold the reset switch.
I guess you didn't understand it has never happened in nearly 2 years and 44,000 miles of RV travel other than my deliberate curiosity testing. There is no need for backup AGM batteries to save a few minutes if it ever did happen. Advanced RV provides owners with much more battery status information as I described beyond idiot lights that any ARV owner can understand. Sometimes the KISS principle applies and adding two AGM batteries is not KISS.
