gregmchugh
- Joined
- Jul 22, 2012
- Posts
- 2,380
Greg,
I've read that. They could have been computer glitches or some other problems I have not encountered. I've had my share but always recovered.I had one shut down from cold temperature when I first got my ARV and that was due to misreading a switch and I had the battery heaters shut off and didn't realize it. When I figured it out I could have prevented it but I let it happen because my experimental mode kicked in and I wanted to see if the shutdown and recovery worked. It did. From that experience ARV has since made that mistake more failsafe with additional positive feedback redundancy on the Silverleaf screen as I described earlier. That is also now how I can monitor when the battery heating pads come on and how long they might stay on at given temperatures.
My only other time was deliberate to drive down the SOC without Autogen activated and everything worked as described in ARV's manual including that need to hold down a toggle switch until a readable 1% SOC back to 21% brought power back on. I'll take that might never happen little inconvenience over carrying an AGM battery with its own issues.
I also had a moisture problem in heavy sudden rains that shorted out the battery electronic sensor connections. In that case the batteries came back online automatically with no need to hold the toggle switch when the connections dried out. As it turned out a sudden pressure differential was sucking water into the supposedly sealed battery case. That was solved by a dime-sized Gortex valve on the case. I have an insulated fiberglass case. ARV, I noticed, is now building insulated stainless steel boxes as of last spring but I have no knowledge of what they are now doing beyond that. The stainless steel boxes eliminated all the heavy iron mounting cage that was protecting my battery case. The skid plate protector is still there. I had the very first build using Elite Power Solutions GBS batteries. I was a big boy and knew what I was getting in to.![]()
This second year everything has been bullet proof so far though I have had Balmar regulator temperature sensor issues, Nation alternator issues (and why I enthusiastically upgraded to that Delco), macerator failure and a VB Air Suspension bag leak. Advanced RV has taken care of all that immediately either at their shop, a field visit, or in my case Mercedes Benz dealers in Scottsdale, AZ and Shreveport, LA. I took care of my own Sprinter problem of the power steering line freakingly coming off at the Mercedes Benz dealer in Littleton, CO. All in all, those three visits to MB dealers cost me about 6 hours of total wait time at the dealers. I have a good impression of MB service.
If the SOC is over 20% on a shut down the restart toggle hold is almost instantaneous so you can deliberately shut down your battery bank for storage and not have that hold down agony. I understand as you surmised ARV can plug in a computer and read a log of what had happened to their electronics. They had done that when I was in their shop.
Very good, thanks for the info...
