Lithium battery storage in bitter cold
Original Member Title: Lithium battery storage in bitter cold
A member storing a Ford Transit Class B through northern Vermont winters asked whether lithium house batteries could remain in the van at 80% charge, with the cutoff switch off, during prolonged temperatures of 20° to 30° below zero. Multiple members recommended indoor storage or a heated battery compartment rather than prolonged exposure below their cited -4°F limit, along with reducing storage charge to around 50% or lower. Another concern was verifying that the disconnect isolates...
Jul 28, 2019
13
With winter right around the corner I’ve winterized the plumbing on my Ford Transit 350HD, but having just this year switched from motorcycle camping to a Class B I’m clueless about the house batteries. Our winters here in northern Vermont hit 20° below for a couple months, with a few weeks at 30° below. The van is under a carport that keeps snow and ice off, but offers no protection from the cold. I’ve got the house batteries at 80% and the cut out switch is off, isolating them from the solar panels.
Is that all I need to do for winter? If not being charged can they handle the cold till our little state thaws out next April or May?
Pete
It is our understanding that lithium should not be subjected to temperatures below -4F. It takes hours, possibly days before the 'mass' of your batteries actually drops to ambient temperatures. But you've implied that we could be talking, not merely days, but a week or more below -4F. We wouldn't leave our lithiums exposed to those temperatures. Either remove them to the interior or create a confined space around the batteries that you can heat. You'll be surprised how little heat is required to maintain a small space, especially if insulated, at a safe temperature. Monitor the battery space temperature to make certain you're not under or over-heating the small space.
Incidentally, current wisdom is that it is best to store lithium over longer periods of disuse at lower the States of Charge (SoC). 80% is high . . . we'd consider 50% or even lower.
I agree with Winston on this. Both of those recommendations are the latest recommendations to help preserve the batteries.
Another thing to be absolutely sure of is that there is a low temp automatic cutout on the battery charging and use as you will under both of those limits, most likely. Sometimes, even the master disconnect does not disconnect all the charge sources, like solar and engine charging so you need to be certain your make and model will be completely disconnected. Taking the cables off the battery is always the safest bet.
The last thing you want is to start the engine and have it start to charge the batteries as too low a temperature.
Thanks.
I’m not sure if my BB batteries have a heat element as the bank is almost fully enclosed. It was a southern van with no rust but also not built with cold in mind. I’ll need to remove the mattress and a few bed slats to get a better view from the top, and several pocket hole screws to remove the side panel for that view. That would also facilitate removal for storage inside.
I’ve seen small heating pads that fit under each battery and wonder if that would be an option.If not I’ll wrestle them into the basement and modify the station for easier access
Thanks.
Heaters are only going to work if you have shore power, as they would kill the batteries without. The problem is the shore charger will probable come on to run them as most heaters are 12v in 12v systems. Current recommendations form many lithium battery manufacturers are to not float charge lithium, but there are also a lot that say it is OK.
If the batteries are inside the van as it appears, you could use a 110v space heater to heat the area enough so they survive.
Using a space heater is an interesting thought. We have one we rarely use, and with the batteries walled off as they are the space wouldn’t be difficult to keep warm. We sometimes lose power in winter but it tends to happen in the warmer months (around freezing) when wet heavy snow or ice bring branches down on the power lines. When that happens we have a couple large Bluettis on standby
I use an incandescent bulb for heat when it gets below -4°. My cheap Bluetooth thermometer tells me that works fine, but it’s not nearly as cold here as where you are
